Calculating Energy Uncertainty for a Particle Described by a Wave Function
  • Thread starter Thread starter Uniquebum
    Delta Uncertainty
The discussion revolves around calculating the energy uncertainty \(\Delta E\) for a particle described by a wave function that is a linear combination of two orthonormal energy eigenstates. Participants are exploring the appropriate operators and methods to determine the expectation values needed for this calculation.
  • Conceptual clarification, Mathematical reasoning, Assumption checking
  • Participants are considering whether to use the total energy operator or the kinetic energy operator for their calculations. There is uncertainty about how to handle expectation values in the context of the given wave function.
  • Some participants suggest that the energy can be expressed in terms of the coefficients and eigenvalues, while others question the necessity of using operators versus constants.
  • There is a discussion about the implications of using the Hamiltonian operator versus the time-dependent energy operator, with some participants expressing confusion about the correct approach.
The conversation is ongoing, with participants providing insights and clarifications regarding the use of operators and the relationship between the wave function and energy eigenstates. Some guidance has been offered about expressing energy in terms of eigenvalues, but there is still exploration of the correct methods to apply.
Participants are navigating the constraints of the problem, including the requirement to work with orthonormal wave functions and the implications of the time-independent Schrödinger equation. There is a recognition that assumptions about operators and their roles in the calculations need to be clarified.
Uniquebum
Determine the energy uncertainty [itex]\Delta E = \sqrt{<E^2> - <E>^2}[/itex] for a particle described by a wave function
[itex]\Psi (x) = c_1 \psi (x)_1 + c_2 \psi (x)_2[/itex]
where [itex]\psi_1[/itex] and [itex]\psi_2[/itex] are different (orthonormal) energy eigenstates with eigenvalues [itex]E_1[/itex] and [itex]E_2[/itex].
I'd presume you need to know
[itex]\hat E = i \hbar \frac{\partial}{\partial t}[/itex]
[itex]\hat E_{kin} = -\frac{\hbar^2}{2m} \frac{\partial^2}{\partial x^2}[/itex]
First, I'm not sure whether i should throw in the kinetic or total energy operator. If i put in the total energy operator, i'll have to derivate the function in respect to time which in this case would result in 0. If i put in the kinetic energy operator it just might work but I'm not sure how i work with those expectation values when they're of the form <E^2> or <E>^2.
Assuming i'd use the total energy operator, should it look like
[itex]<E^2> = \int_{-\infty}^{\infty} \psi^* (x) i^2 \hbar^2 \frac{\partial^2}{\partial t^2} \psi (x)[/itex]
[itex]<E>^2 = \int_{-\infty}^{\infty} \psi^* (x)^2 i^2 \hbar^4 \frac{\partial^2}{\partial t^2} \psi (x)^2[/itex] ?
Any help would be appreciated.
Note that
[tex]\langle E \rangle_\Psi \equiv \langle \Psi \mid E \mid \Psi \rangle[/tex]
Since you are given that the wave function is a linear combination of orthonormal energy
eigenstates you can work out what <E> is in terms of c1,2 and E1,2. Squaring that will give you <E>2.
You can do a similar trick for
[tex]\langle E^2 \rangle_\Psi \equiv \langle \Psi \mid E^2 \mid \Psi \rangle<br /> = \left( \langle \Psi \mid E \right) \left( E \mid \Psi \rangle \right)[/tex]
Hmm... so in this case [itex]\hat E_{12} = E_{12}[/itex]? Meaning i don't have to mess around with the operators but i can just put in the constants E_1 and E_2?
Sorry, what do you mean by [itex]\hat E_{12}[/itex]?
Maybe I wasn't entirely clear with:
What I meant is:
you can work out what <E> is in terms of c1 and of c2 and of E1 and of E2.
But yes, you can work it out in terms of eigenvalues rather than using the explicit form of the operator - but of course you will still need to work it out to some extent (you can't just call the energy E, you do need to get it in terms of the given constants)
[edit]
Just to be completely clear on what I mean: can you tell me (from the given information) what [itex]\hat E { |\Psi\rangle}[/itex] is?
[itex]\int_{-\infty}^{\infty} \Psi^* \hat E \Psi dx[/itex], where [itex]\hat E = i \hbar \frac{\partial}{\partial t}[/itex]
But i figured i can just ignore the operator and use E instead. Which would lead into
[itex]<E> = \int_{-\infty}^{\infty} \Psi^* \hat E \Psi dx = \int_{-\infty}^{\infty} (c_1^* \psi (x)_1^* + c_2^* \psi (x)_2^* )\cdot(c_1 E_1 \psi (x)_1 + c_2 E_2 \psi (x)_2)dx[/itex]
You can't just ignore stuff. That's a sign that you're making a mistake. In this case, you're using the wrong operator to find the energy. You should be using the Hamiltonian [itex]\hat{H}[/itex] because your wave function is a solution to the time-independent Schrödinger equation [tex]\hat{H}\psi(x) = E\psi(x)[/tex] where E is a constant, not an operator. The operator [tex]\hat{E} = i\hbar\frac{\partial}{\partial t}[/tex] works on solutions [itex]\Psi(x,t)[/itex] to the time-dependent Schrödinger equation [tex]\hat{H}\Psi(x,t) = i\hbar\frac{\partial}{\partial t}\Psi(x,t).[/tex]
The expected value of the energy E is then
[tex]\langle E \rangle = \int_{-\infty}^\infty \psi^* \hat H \psi \, dx = \int_{-\infty}^\infty [c_1^* \psi_1^*(x) + c_2^* \psi_2^*(x)][c_1 E_1 \psi_1(x) + c_2 E_2 \psi_2(x)]\,dx[/tex]
Ok, so the way i thought you'd do it led to the right equation but it was pure luck since i just guessed the way it'd go. This definitely helped even more than just considering the solution to the main question.
Anyway, the rest should be fairly simple since i just have to take into account that the wave functions are orthonormal. Which mainly means that the wave functions will disappear since they'll be multiplying each others and thus be 1 or 0. I'll give it a shot. Thanks!
  • · Replies 30 ·
