How Do Phase Changes Affect Energy Calculations in Ethanol?
  • Thread starter Thread starter nobb
    Energy Phase
The discussion focuses on calculating the molar heat of vaporization for ethanol using two specific problems involving phase changes. For the first problem, the molar heat of vaporization was calculated to be 65,742.5 J/mol by applying the formula Q = m × c × ΔT and combining the energy required for vaporization and condensation. The second problem involves determining the mass of an ice cube placed in ethanol, utilizing the same heat energy equation and the latent heat of fusion. Both problems emphasize the importance of understanding phase changes and specific heat in thermodynamic calculations.
  • Understanding of thermodynamic principles, specifically phase changes.
  • Familiarity with specific heat capacity calculations.
  • Knowledge of the latent heat of fusion and vaporization.
  • Ability to perform calculations involving mass, temperature change, and energy transfer.
  • Study the concept of molar heat of vaporization in detail.
  • Learn about the latent heat of fusion and its applications in phase change problems.
  • Explore advanced thermodynamic equations and their derivations.
  • Practice solving problems involving specific heat and phase changes with different substances.
Students in chemistry or physics courses, educators teaching thermodynamics, and anyone interested in understanding energy calculations related to phase changes in substances like ethanol.
nobb
Hey...I am having a little problem with my homework. Here are the two questions:
1. 6.66g of ethanol gas at 78.3 degress celsius (boiling pt) was bubbles into 60g of liquid ethanol at 12.3 degrees celsius, heating it to 52.3 degrees. Specific heat for ethanol (l) is 2.6 g/(g degrees celsius). Use this data to calculate the molar heat vaporization for ethanol.
2. 30g of ethanol(l) (c=2.6 j/(g degrees celsius)) at 50 degrees has an ice cube at 0 degrees placed in it and the temperature drops to 14.5 degrees. Calculate the mass of the ice cube.
Could someone please explain to me how these questions are done? Thanks.
For the first question, you need to use the equation q = m × c × ΔT, where q is the amount of heat energy, m is the mass of the ethanol, c is its specific heat, and ΔT is the change in temperature. Using this, you can calculate the amount of heat energy absorbed by the liquid ethanol. You will then use the molar heat of vaporization equation, q = ΔHvap, where ΔHvap is the molar heat of vaporization, to solve for the molar heat of vaporization. For the second question, you will use the equation q = m × c × ΔT, where q is the amount of heat energy, m is the mass of the ethanol, c is its specific heat, and ΔT is the change in temperature. You can then calculate the amount of heat energy that must be removed from the ethanol to lower its temperature. You will then use the formula, q = mL, where mL is the latent heat of fusion of the ice, to calculate the mass of the ice cube.
Hey there! It looks like you're having trouble with some phase change problems involving ethanol. Don't worry, I can help you out with these questions.
For the first question, we need to use the formula Q = m x c x ΔT, where Q is the amount of energy, m is the mass, c is the specific heat, and ΔT is the change in temperature. We also know that the energy needed for a phase change is equal to the molar heat of vaporization (ΔHvap) times the amount of substance (in moles). So, we can set up our equation like this:
Q(l to g) + Q(g to l) = ΔHvap x n
Where Q(l to g) is the energy needed to vaporize the liquid ethanol, Q(g to l) is the energy released when the vapor condenses back to liquid, and n is the number of moles of ethanol.
Now, let's plug in the values we know:
Q(l to g) = m x c x ΔT = (60g) x (2.6 g/(g degrees celsius)) x (52.3 - 12.3 degrees) = 7,800 J
Q(g to l) = m x c x ΔT = (6.66g) x (2.6 g/(g degrees celsius)) x (78.3 - 52.3 degrees) = 1,710.6 J
We can then combine these two equations and solve for ΔHvap:
7,800 J + 1,710.6 J = ΔHvap x n
9,510.6 J = ΔHvap x (6.66g / 46.07 g/mol) = ΔHvap x 0.1447 mol
ΔHvap = 9,510.6 J / 0.1447 mol = 65,742.5 J/mol
So, the molar heat of vaporization for ethanol is 65,742.5 J/mol.
For the second question, we can use a similar approach. We know that the energy released by the ethanol (ΔHfus) is equal to the energy absorbed by the ice (ΔHfus). We can set up our equation like this:
Q(ethanol) = -Q(ice)
Where Q(ethanol) is
  • · Replies 131 ·
11K
15K
16K
