Calculating Final Velocity of a Car Rolling into a Station
The problem involves calculating the final velocity of a car that runs out of gas while rolling towards a service station, considering both kinetic and potential energy. The car's initial speed, mass, and the elevation change to the station are provided, along with a specific answer mentioned by the original poster.
  • Exploratory, Conceptual clarification, Mathematical reasoning, Assumption checking
  • Participants discuss using kinematic equations and the conservation of energy to approach the problem. Some suggest calculating gravitational components and energy transformations, while others question the relevance of the car's mass and distance to the solution.
Several participants have offered guidance on potential methods to solve the problem, including energy conservation principles and kinematic equations. There is a variety of interpretations regarding the necessary components for the calculations, but no explicit consensus has been reached.
There is a mention of neglecting friction and a specific elevation change, which may influence the calculations. Additionally, one participant humorously questions the feasibility of the scenario based on the car's mass.
albert611
Hi, I attempted this problem, but I do not see how it makes sense. Could somebody give me an idea of how to solve this problem? Thanks!
While traveling along at 24.3 m/s, a 13.7 kg car runs out of gas 16 km from a service station. Neglecting friction, if the station is on a level 14.8 m above the elevation of the car, how fast will the car be going when it rolls into the station?
The correct answer should be 17.33 m/s BTW.
Thank you very much for your help!
-Albert
Well, let's see.
Find the component of gravity that is slowing down the car. That'll be your negative acceleration. You have all the other information. Use the appropriate kinematic equation, plug and chug.
Also, if you know how to calculate potential gravitational energy and kinetic energy you could use the energy conservation law.
In other words:
1) find the kinetic energy of the car using Ek= (1/2)mv2.
2) find the increase in potential energy as the car moves up to the gas station using
Ep= mgh.
3) find the kinetic energy of the car at the gas station assuming conservation of energy
4) find the speed of the car from the kinetic energy using, again Ek= (1/2)mv2.
I would advise setting up the problem as follows
[tex]KE_i+U+i=KE_f+U_f[/tex]
KE=Kinetic Energy
U=Potential Energy
KE=1/2 m v^2
U=mgy
We can assume the [tex]U_f[/tex] will go to zero
[tex]1/2mv^2 = 1/2mx^2 + mgy[/tex] solving for x
the m's cancel out
[tex]1/2 v^2 = 1/2 x^2 + gh[/tex]
solve for x and volla 17.3323
so end the end you did not need to know the cars mass or the 16 miles... go conservation of energy
A 13.7 kg car? It'll be blown away by the wind before it gets there!
  • · Replies 22 ·
14K
11K
