Flywheels and Rotational Motion
The discussion revolves around the use of a flywheel for energy storage in automobiles, specifically focusing on the calculations needed to determine the energy required for a vehicle to travel a specified distance under certain conditions. The subject area includes concepts from rotational motion and energy conservation.
  • Exploratory, Conceptual clarification, Mathematical reasoning, Assumption checking
  • The original poster attempts to apply the principle of conservation of energy, questioning how to initiate their calculations. Some participants suggest incorporating rotational kinetic energy into their analysis. Others raise concerns about the implications of flywheel energy storage in scenarios such as accidents and energy management during travel.
The discussion is ongoing, with participants providing various insights and considerations regarding the calculations and implications of using a flywheel. Some guidance has been offered on how to approach the problem, particularly regarding the work done by friction over the distance traveled.
Participants are working under specific assumptions about frictional forces and energy recovery during downhill travel. There are also considerations about the practicality and safety of using flywheels in automotive applications.
Soaring Crane
One possibility for a low-pollution automobile is for it to use energy stored in a heavy rotating flywheel of mass 240 kg, and should be able to travel 300 km (300,000 m) without needing a flywheel "spinup."
Make reasonable assumptions (avg. frictional retarding force 500 N, 20 acceleration periods from rest to 90 km/h or 25 m/s, equal uphill and downhill --assuming during downhill, energy can be put back into the flywheel), and show that the total energy needed to be stored in fly wheel is about 1.6 x 10^8 J.
I need help to start this proof. Do you use K_i + U_i = K_f + U_f? What do I do from here?
Thanks for any pointers.
try using K_rotatational also
k_rot = (1/2)IW^2 --> I is inertia, W is omega (angular speed)
What happens to the energy stored in the flywheel if you should be come involved in an accident? I have visions of a massive flywheel with a large rotational kinetic energy busting loose from its housing and ripping off down the road destroying car after car, each of which releases a flywheel! Talk about a chain reaction accident!
Yeah, I know that is a bit extreme, but containment is an issue.
Also spinups will be necessary. Suppose I drive from my home at 100m to spend a week in the mountains at 1000m? A spinup may well be necessary to meet my needs for a week. Now on the way home, I may find myself with more energy to store then the flywheel is designed for.
Just some thoughts, the fact is, for years I have speculated about using a flywheel for automotive energy storage.
Now to address your question!
According to your assumptions the only loss will be that due to friction. If you simply compute the work done by your friction force over 300km, you should have your answer.
  • · Replies 23 ·
