Can a Compressed Spring Launch You Over a 15-ft Wall?
The discussion centers on the feasibility of using a compressed spring cannon to launch a person over a 15-ft wall. The spring, which is 10-ft long, is compressed to 1/10 of its normal length, and the potential energy stored in the spring must exceed the gravitational potential energy required to reach the height of the wall, plus the kinetic energy at the peak of the trajectory. The condition for success is established as 1/2 k D^2 > mgh, where k is the spring constant, D is the compression distance, m is the mass of the person, g is the acceleration due to gravity, and h is the height of the wall. The analysis concludes that with the right parameters, it is indeed possible to clear the wall.
  • Understanding of spring mechanics and potential energy
  • Knowledge of kinematics and projectile motion
  • Familiarity with the concept of spring constant
  • Basic algebra for solving inequalities
  • Calculate the spring constant using k = mg/2 for different weights
  • Explore the principles of energy conservation in mechanical systems
  • Study projectile motion equations to analyze trajectory
  • Investigate real-world applications of spring-powered launch systems
Physics students, engineers, and hobbyists interested in mechanics, energy transfer, and practical applications of spring systems.
yellowstriker
There is a "cannon" that is a 3-ft diameter tube that is 12-ft. long with a stiff spring inside. The spring will be compressed to 1/10 its normal length and held. You will be on the spring. With perfect aim you will fly through the air over a 15-ft wall and land safely in a net. The spring is 10-ft. long. When you hang on the spring w/o touvhing the ground it stretches by 2-ft. Is it possible to make it over the wall?
This smells like homework!
I don't understand the problem. YOu state "you will fly through the air over a 15-ft wall and land safely in a net", then ask "is it possible to make it over the wall". Didn't you just say it was??
I guess the problem is to find the potential energy stored in the spring when it is compressed, convert that to kinetic energy as you leave the cannon to find your initial speed and then use kinematics to determine if the maximum point of the trajectory really is more than 15 ft. To do that, you need to know the "spring constant" for the spring.
That's probably the point of "When you hang on the spring w/o touvhing the ground it stretches by 2-ft." but, while I know my weight and so could find the force on the spring when I hang on it I don't know yours so my solution wouldn't necessarily work for you! Does the problem give a weight for the person?
The condition for success is:
Spring potential energy > mgh + KEtop where h is the height of the wall and KEtop is your kinetic energy at maximum height (vertical speed = 0). There has to be some extra energy in the spring to provide horizontal acceleration to give you a horizontal velocity to actually get over the wall but ignore that for the moment
So:
[tex]\frac{1}{2}kD^2 > mgh[/tex]
To determine K, we know that it stretches 2 feet due to your weight so:
kd=mg where d =2 so k = mg/2
I think you will find that the inequality is satisfied leaving more than enough for the needed Kinetic energy to provide horizontal travel.
AM
10K
9K
