Looking for help Setting up a Power Recovery Circuit
  • Thread starter Thread starter Mastiffman
    Circuit Power
The discussion focuses on setting up a Power Recovery Circuit for a Generator Head, emphasizing the use of a Full Wave Bridge Rectifier, capacitors, and a Timing Switch. The Full Wave Bridge Rectifier is essential for converting AC to DC, while capacitors are used to maintain low resistance and store energy. The Timing Switch is crucial for managing the discharge rate of the capacitors to ensure efficient power delivery. Participants seek recommendations for circuit setup and additional resources for further understanding.
  • Understanding of Full Wave Bridge Rectifiers
  • Knowledge of capacitor functions in electrical circuits
  • Familiarity with Timing Switch applications
  • Basic principles of generator operation and efficiency
  • Research the design and implementation of Full Wave Bridge Rectifiers
  • Learn about capacitor selection and sizing for power recovery applications
  • Explore Timing Switch configurations for optimal discharge rates
  • Investigate advanced power recovery techniques in generator systems
This discussion is beneficial for electrical engineers, hobbyists working with generators, and anyone interested in optimizing power recovery systems for improved efficiency in generator applications.
Mastiffman
Hello there Everyone!
I was interested in connecting up a Power recovery Circuit to a Generator Head and have been doing some reserch on it... The few components that will be key are:
1. Full Wave Bridge Rectifier (To convert the AC to DC)
2. Capacitors (To create the load while keeping the resistance low)
3. Some type of Timing Switch (I'm assuming to keep the caps dishcarging rapidly enough to store and discharge in a manner that is equal or better in quality to a typical Power Supply)
If someone could give me some recommendations on this circuit and how it will need to be setup, that would be greatly appreciated! Or some more reading that will guide me there...
Thanks in advance!
Thanks in advance!
What's a "Generator Head", and why do you want to recover power from it?
Thanks for the response.
Sorry, I dind't want to confuse a Generator (Gasoline power engine driven) with just the generator motor itself.
I want to use the generator as a generator... But, with little bemf to maintain as close to full rpm's as possible with as little mechanical power as possible. This can be acheived through the use of a Power Recovery Circuit. The Capacitors act a load retreiving and storing the electricity and disharging it to the actual Load put on the generator.
9K
