Are x, y, and z elements of the normed linear space ℓ∞(ℝ)?
  • Thread starter Thread starter bugatti79
    Linear Space
The discussion centers on the elements x, y, and z in the normed linear space ℓ∞(ℝ). It is established that x = (n-1)/n and y = 1/n are elements of ℓ∞(ℝ) as they are bounded above, while z = 2^n is not an element due to being unbounded. The calculations for x + y and 2^(1/2)y reveal that both results are not in ℓ∞(ℝ). The infinity norms are calculated, confirming that ||x||∞ = 1, ||y||∞ = 1, and ||x+y||∞ = 1, while ||2^(1/2)y||∞ is also determined to be 1.
  • Understanding of normed linear spaces, specifically ℓ∞(ℝ)
  • Familiarity with sequences and their properties
  • Knowledge of the concept of boundedness in mathematical analysis
  • Ability to compute limits and supremums in sequences
  • Study the properties of normed linear spaces, focusing on ℓ∞ spaces
  • Learn how to compute the supremum of sequences
  • Explore the concept of bounded and unbounded sequences in functional analysis
  • Investigate the implications of the infinity norm in various mathematical contexts
Mathematics students, particularly those studying functional analysis, as well as educators and researchers interested in normed linear spaces and sequence properties.
bugatti79
Consider the normed linear space [itex]\ell_\infty \mathbb({R})[/itex]. Let [itex]x= \frac{n-1}{n}[/itex], [itex]y=(1/n) and z=2^n[/itex]
a) Are x,y,z each in [itex]\ell_\infty \mathbb({R})[/itex]
b) What is x+y? What is [itex]2^{1/2} y?[/itex]
c) Calculate [itex]||x||_\infty[/itex], [itex]||y||_\infty[/itex], [itex]||x+y||_\infty[/itex] and [itex]||2^{1/2} y ||_\infty[/itex]
For a) Does that mean are x,y,z subspaces of [itex]\ell_\infty \mathbb({R})[/itex]?
No, x, y, and z are sequences. The question is asking whether they belong to [itex]\ell_\infty \mathbb({R})[/itex].
x and y are each an element in l_∞ as they are bounded above
z is NOT an element as its not bounded above
In b) what does it mean by 'what is'. Is that asking to evaluate?
You could answer b by evaluating x + y, and then saying whether it is in l(R).
bugatti79 said:
1. Homework Statement
x+y =n implies (n) =(1,2,3,4...) which is not in l∞(R) sicne it is not bounded above.
2^(1/2)*y= 2^(n+1/2) which is not in l∞(R) either...?
Yes, but here's how to say the first part better. x + y = {n} = {1, 2, 3, ...}
No, 21/2y = 21/2{1/n}. That means 21/2 times each element of the sequence {1/n}.
Thanks..that was a mistake on my part. So hence it IS in l∞(R)
For c) do I attempt to evaluate each?
Yes and yes.
Your textbook should have a definition of the infinity norm - if not, there's one in the link I posted in the other thread.
Hmm, I get a different result for x+y... :confused:
Let's make that x + y = {1} = {1, 1, 1, ...}
For x:
1-1/n =(0,1/2,2/3,3/4...) and is bounded.
[itex]||1-1/n||_∞[/itex]=...? I am not sure how to calculate this. If some one can illustrate this one, I can try the others...? I know [itex]||1-1/n||_∞=sup |x_n|[/itex] but don't know how to calculate |x_n|
Thanks
Mark44 said:
See http://en.wikipedia.org/wiki/Lp_space, in the section titled Lp spaces, starting with "One also defines the ∞-norm as ...".
I believe that this is the norm to be used in your problem.
THanks Mark but how to I evalute |x_n|?
What is the supremum of the set {0, 1/2, 2/3, 3/4, ..., n/(n + 1), ...}?
I think the supremum is the smallest real number that is greater than or equal to every number in the set, hence t must be 0...?
What do i do next?
Is it something along the lines of
[itex]|1-1/n|=\sqrt{(1-1/n)^2}=0[/itex] where n=1
Yes.
No. 0 is smaller than, not larger than every number in the sequence except the first.
bugatti79 said:
What do i do next?
Mark44 said:
Yes.No. 0 is smaller than, not larger than every number in the sequence except the first.
Then it doesn't exist, there is no sup...?
Yes! So what is the smallest number that is >= each number in the sequence {0, 1/2, 2/3, 3/4, ..., n/(n+1), ...}
No, it can't be 0. This number is too small, because it's not larger than 1/2 (for example). 2589 is larger than all the numbers in the sequence, but can you find one that is not so large?
1 would be greater than or equal to every number in the set...?
a reasonable guess, can you prove it?
Yes. Why are you uncertain?
Although not required in the problem, Deveno's question is reasonable, given the uncertainty in the answer above.
All I know is that |1- 1/n| < 1 but I don't know to prove its 1.
|1 - 1/n| is never 1.
but...perhaps there might be a least upper bound. what are our likely candidates for this office?
What is:
[tex]\lim\limits_{n \to \infty} (1 - {1 \over n})[/tex]
I like Serena said:
What is:
IF n tends to infinity then the modulus tends to 1 but never 1...so does that mean that
||1- 1/n||_∞=sup |1-1/n|=1?
I don't understand your uncertainty either.
I'm just going to say yes, it is 1.
what does:
[tex]\lim_{n \to \infty} f(n) = L[/tex]
mean?
if you have such a limit, and, you know that f(n) < L for all n, what must sup{f(n)} be?
Deveno said:
what does:
mean?
That L is a finte real number and in this case it is a 1.
Deveno said:
what does:
mean?
You didn't answer Deveno's question. He asked, what is sup{f(n)}?
Is it L?
