Need Help Solving Water Tank Experiment
  • Thread starter Thread starter Jack16
The water tank experiment involves generating water waves through two openings spaced 5.0 cm apart in a wooden board, with a wavelength of 2.5 cm. The diffraction equation Yk/D = kλ/d is used to analyze the wave patterns. The first minimum of destructive interference occurs at a 90-degree angle from the straight-through direction, indicating that standing at this angle will result in little to no wave action. Understanding the relationship between wave number, wavelength, and diffraction is crucial for solving this problem.
  • Understanding of wave mechanics and interference patterns
  • Familiarity with the diffraction equation Yk/D = kλ/d
  • Knowledge of wave number (k) and wavelength (λ)
  • Basic concepts of constructive and destructive interference
  • Study the principles of wave interference in detail
  • Learn about the applications of the diffraction equation in various contexts
  • Explore the concept of wave number and its significance in wave physics
  • Investigate real-world examples of diffraction patterns in different mediums
Students and educators in physics, particularly those focusing on wave mechanics and experimental physics, as well as anyone interested in understanding wave interference and diffraction phenomena.
Jack16
I Need Some Help:(...
In a water tank experiment,water waves are generated with their srests 2.5 cmapart and parallel.they pass through two openings 5.0 cm apart in a long wooden board.If the end of the tank is 2.0 m beyond the boards,where would you stand ,relative to the "straight - through " direction,so that you received little or no wave action?
this question seems very easy but i just could not end up solvin it ,i used the equation Yk/D = k x lambda /d ,but i couldn't quiet understand how i would find where it would have no wave reaction
I am waiting for your comments,
thanks already...
you want have any wave where the two waves which are coherent meet out of phase and cancel each other out...
so from the given data we can see that lambda=2.5cm, D=200cm, x=5cm So you can find the separation the first "dark" fringe has with the central one.
2.5=5y/200 So y=100cm
Although I have not completely understood the tern "Straight through" I think Iam correct
Hello there,
I can understand your frustration with this experiment. It can be tricky to solve, but let me break it down for you.
First, let's define some variables:
- Yk: distance from the center of one wave crest to the center of the next crest
- D: distance between the two openings in the wooden board (5.0 cm in this case)
- k: wave number, which is equal to 2π/λ (where λ is the wavelength)
- d: distance from the openings to the end of the tank (2.0 m in this case)
Now, the equation you mentioned (Yk/D = kλ/d) is known as the diffraction equation. This equation tells us that the distance between two wave crests (Yk) is equal to the product of the wave number (k) and the wavelength (λ), divided by the distance between the openings (D) and the distance from the openings to the end of the tank (d). This equation is used to calculate the diffraction pattern of the waves as they pass through the openings.
To find where there will be little to no wave action, we need to look at the diffraction pattern. This pattern will show us where the waves interfere constructively (creating larger waves) and where they interfere destructively (canceling each other out).
In this case, since the two openings are 5.0 cm apart, the diffraction pattern will be symmetrical and the first minimum (destructive interference) will occur at an angle of 90 degrees from the straight-through direction. This means that if you stand at a 90-degree angle from the straight-through direction (either to the left or right), you will receive little to no wave action.
I hope this helps you solve the experiment. If you have any further questions, feel free to ask. Good luck!
  • · Replies 22 ·
  • · Replies 20 ·
