Limit the RPM of output Shaft having variable input RPM from another shaft
The discussion revolves around the challenge of limiting the RPM of Shaft B to a maximum of 400 RPM while Shaft A receives variable input RPM from another rotating element, ranging from 0 to 2000 RPM. Participants explore potential mechanisms to achieve this limitation, considering constraints such as size and resistance to rotation.
  • One participant suggests that a transmission could serve the purpose of limiting RPM.
  • Another participant proposes friction gearing or a continuously variable transmission (CVT) as possible solutions.
  • Concerns are raised about friction gearing leading to wear and CVT potentially offering high resistance to rotation.
  • A participant mentions the difficulty of achieving the desired specifications, including negligible resistance, minimal maintenance, and size constraints.
  • Reference is made to the hybrid synergy drive as a potential model for consideration.
  • Another participant suggests a variant of an overrunning clutch, emphasizing that the connection between the shafts is crucial for determining the effectiveness of this approach.
  • There is a suggestion that if a control system and actuators were used, the task could be simplified significantly.
Participants express differing opinions on the feasibility and effectiveness of various mechanisms proposed to limit RPM. No consensus is reached on a specific solution, and the discussion remains unresolved regarding the best approach.
Participants highlight limitations regarding the desired characteristics of the mechanism, including size, resistance to rotation, and maintenance needs, which complicate the search for a suitable solution.
abhinavsgupta
Hi
Shaft A has variable RPM, getting input from some rotating element (say X), ranging from 0 to 2000.
The RPM of X cannot be adjusted or controlled.
A has to transfer the rotation with limiting RPM of upto 400 to Shaft B.
Is there a way to limit the RPM using a mechanism such that at particular RPM, Shaft B have constant RPM irrespective of Shaft A RPM.
Example:
Shaft A RPM= 350 Shaft B RPM= 350
Shaft A RPM= 400 Shaft B RPM= 400
Shaft A RPM= 1200 Shaft B RPM= 400
Shaft A RPM= 2000 Shaft B RPM=400
Also I would like to mention that due to space constraint a bulky system/mechanism cannot be accommodated. Thus I want a small system of nearly or less then 6 inches(LBH) size.
This is what a transmission does.
Thanks for updating my knowledge, but my query is still unsolved. I m looking for a mechanism which is smaller in size and whose resistance effect to rotation is almost negligible.
Friction gearing would lead to wearing of the fiber and my perception with CVT is that it will offer high resistance to rotation. I am looking for something which do not offers high resistance to rotation and is much more like maintenance free.
...Sorry, but tough luck...
MAYBE if you developed your own control method and magnetic coupling design (something like a Powered & Free design). But I don't see this working; and I see it being very expensive and finnicky.
Think about what you are asking:
--You want to turn down 2000 RPM to 400
--You want negligible resistance
--you want negligible wear
--you want minimal maintenance
--you want it to be less than 6 in. (in any dimension?)
I don't want to discourage you, but engineering is about optimizing not idealizing.
Take a look at the operation of the hybrid synergy drive, too
A variant of an overrunning clutch would do the job. It totally depends on how the shafts are connected, which I can't visualise from the above.
Input shaft geared down then a clutch based on the output shaft speed that would disengage (fully or slip) at 400 rpm.
If you didn't need to do it mechanically, ie you had a control system and some acutators. It'd be easy.
Fo Sho
@ Travis: Thanks for providing the information of hybrid synergy drive but I can't find anything useful as req. If you could just suggest me some better mechanism.
@Chris : Thanks for the input. If you could just suggest me some specific overrunning clutch system as per my req.
The system just requires an intermediate mechanism to limit the RPM of the shaft.
  • · Replies 24 ·
9K
  • · Replies 18 ·
  • · Replies 17 ·
  • · Replies 23 ·
37K
