| New Reply |
Inner product integration |
Share Thread | Thread Tools |
| Nov3-11, 03:23 PM | #1 |
Space of continuous functions.
Inner product [tex]<f,g>=\int_{-1}^{1}f(x)g(x)dx[/tex]. Find a monic polynomial orthogonal to all polynomials of lower degrees. Taking a polynomial of degree 3. [tex]x^3+ax^2+bx+c[/tex] Need to check [tex]\gamma, x+\alpha, x^2+\beta x+ \lambda[/tex] [tex]\int_{-1}^{1}(\gamma x^3+\gamma a x^2 +\gamma bx + \gamma c)dx[/tex] [tex]=\frac{\gamma x^4}{4}+\frac{\gamma a x^3}{3}+\frac{\gamma b x^2}{2}+\gamma c x|_{-1}^{1}[/tex] [tex]=\frac{2\gamma a}{3}+2\gamma c=0\Rightarrow c=-\frac{a\gamma}{3}[/tex] [tex]\int_{-1}^{1}(x^3+ax^2+bx+c)(x+\beta)dx[/tex] [tex]\int_{-1}^{1}\left(x^4+ax^3+bx^2-\frac{a\alpha x}{3}+\beta x^3 +\alpha\beta x^2+b\beta x-\frac{a\alpha\beta}{3}\right)dx=6+10b+10a\beta-10a\alpha\beta=0[/tex] What do I do with that? |
| Nov3-11, 04:51 PM | #2 |
Recognitions:
well, are you given the degree you polynomial is supposed to be, or are you suppose to find a formula for any n (degree)?
for n = 0, we can choose p0(x) = 1 (we don't have any polynomials of lesser degree, so any constant will do. i like 1, don't you?). for n = 1, the only requirement is that <p1(x),c> = 0 for any constant polynomial k(x) = c, that is: [tex]\int_{-1}^1(ax+b)c\ dx = 0[/tex] or: 2b = 0, so b = 0, thus p1(x) = ax. again there is no reason not to choose a = 1. for n = 2, we need <p2,c> = 0, and <p2,ax+b> = 0 if p2(x) = rx2+sx+u, this means r = -3u, from the first inner product, and s = 0 from the second. so p2(x) = u(3x2 - 1). again, any non-zero choice will do, although one might be inclined to choose u such that <p2(x),p2(x)> = 1. now, for n = 3: you may as well assume that γ ≠ 0, since it is arbitrary, which gives: c = -a/3, not c = -aγ/3 (just divide by γ). in your second inner product, you start with x+β, instead of x+α, and somehow wind up with something with α's and β's. huh? pick a variable for the constant term of your generic linear polynomial, and stick with it. |
| New Reply |
| Thread Tools | |
Similar Threads for: Inner product integration
| Integration (inner product) | Calculus & Beyond Homework | 2 | ||
| Integration of the dot product of two vectors | Calculus | 5 | ||
| Integration Involving Dot Product? | General Math | 5 | ||
| integration involving a dot product | Calculus | 12 | ||
