Ideal gas expansion/compression
  • Thread starter Thread starter format1998
    Gas Ideal gas
In ideal gas expansion or compression, the number of moles remains constant unless gas is added or removed. For example, when an ideal monatomic gas is compressed, a decrease in volume by a factor of 0.5 and an increase in pressure by a factor of 4.5 do not affect the number of moles. The relationship between pressure (P), volume (V), and temperature (T) is governed by the ideal gas law, which requires data on at least three of these four variables to solve any problem accurately. Understanding the conditions of the process—whether isobaric, isothermal, or isochoric—is crucial for proper analysis.
  • Understanding of the ideal gas law (PV=nRT)
  • Knowledge of thermodynamic processes (isobaric, isothermal, isochoric)
  • Familiarity with the concept of moles in chemistry
  • Basic algebra for solving equations with multiple variables
  • Study the ideal gas law and its applications in various thermodynamic processes
  • Learn about isobaric, isothermal, and isochoric processes in detail
  • Explore the concept of molar mass and its impact on gas calculations
  • Investigate real gas behavior and deviations from ideal gas laws
Students studying chemistry or physics, particularly those focusing on thermodynamics and gas laws, as well as educators seeking to clarify concepts related to ideal gases.
format1998
this may be a stupid question but i have to ask as my book doesn't specifically say, it'll help me figure out a problem in my homework. So, here it goes...
When an ideal gas expands or is compressed, does the number of moles change or does it remain the same? if it remains the same, does that mean only the volume changes. For instance, in the case of compression of an ideal monatomic gas. Gas is compressed and the volume decreases by a factor of .5, pressure is increased by a factor of 4.5. Does the # of moles increase, decrease, or neither?
Thank you in advance. Any and all help is much appreciated!
In order to solve these problems, you need data about any three of the four variables (P, V, n, T)
Your example only specifies two (P, V). Without a third specification, it's impossible to know if one or both mass and temperature have changed.
I'd like to say "typically" ideal gas problems don't have mass flows associated with them; but that's not really true. There are plenty of open-system ideal gas problems. So proceed with the assumption that mass is constant at your own peril.
You really do need more info. Ideal gases can be compressed and expanded isobarically (const. P), isothermally (const. T), isochorically (const. volume), or in a closed system (const. mass). The problem really should state it--read carefully--or it's incomplete and not well posed. Only mathematicians can solve a two-unknowns problem with one equation. ;-)
If not specified otherwise, assume the number of moles of gas does not change. For the moles to change, either some more gas has to be added to the initial gas present, or some of the initial gas escapes.
When the number of moles is constant, the other quantities (P, V, or T) can still change.
  • · Replies 67 ·
  • · Replies 33 ·
10K
