Pool heat gain by solar radiation versus heat loss by evaporation
The discussion centers on the effectiveness of using 22mm thick black EPE panels to cover a pool in relation to heat gain from solar radiation and heat loss through evaporation. It is established that up to 85% of solar radiation can heat an uncovered pool, while 70% of heat loss occurs via evaporation. The participants debate whether the heat gain reduction from covering the pool with EPE panels outweighs the benefits of reduced evaporation. Ultimately, the consensus leans towards the idea that using EPE panels can maintain a warmer pool temperature.
  • Understanding of heat transfer principles in swimming pools
  • Knowledge of solar radiation effects on water temperature
  • Familiarity with evaporation rates in open water bodies
  • Experience with pool cover materials, specifically EPE panels
  • Research the thermal properties of EPE panels for pool covers
  • Explore the impact of different pool cover materials on heat retention
  • Investigate methods to calculate heat loss due to evaporation
  • Learn about solar radiation absorption rates in various pool cover types
Pool owners, swimming pool maintenance professionals, and anyone interested in optimizing pool temperature management through effective covering strategies.
chrisDH
Hi,
On various websites I read that 70% of the heat loss of a pool is by evaporation, whereas up to 85% of the solar radiation can heat an uncovered pool.
We use 22mm thick black color EPE panels to cover our pool.
On a sunny day, is it better to cover the pool or to leave it uncovered ?
In other words ;
Is the reduction of heat gain (because of the EPE panel cover) compensated by the reduced heat loss by evaporation ?
Thanks for your help
Chris
Science news on Phys.org
How about using a transparent foil cover? It let's the sun in, and keeps the vapor inside.
Hi A.T
thanks, but I've had one of those before. there difficult to remove and you need an ugly big roll beside your pool.
Since I've been using the EPE panels my pool is a lot warmer too.
I just cannot figure out whether it's better to cover the pool during a sunny day or not
rgds
Chris
  • · Replies 21 ·
37K
9K
29K
