Limit of Sequence: Help Solving Equation
  • Thread starter Thread starter twoflower
    Limit Sequence
The discussion revolves around evaluating the limit of a sequence defined as \(\lim_{n \rightarrow \infty} n \left( \left( 1 + \frac{1}{n} \right)^{n} - e \right)\), which involves concepts from calculus and sequences. Participants are exploring various methods to approach this limit without using l'Hospital's rule.
  • Exploratory, Conceptual clarification, Mathematical reasoning, Assumption checking
  • Some participants suggest using Taylor series expansions for \(\log(1+x)\) and \(e^x\) to analyze the limit. Others express confusion about the appropriateness of using series given their current syllabus. There are discussions about the implications of substituting known limits and the behavior of the sequence as \(n\) approaches infinity.
Participants are actively engaging with different approaches, including series expansions and inequalities. There is a recognition that Taylor series may be the most straightforward method to tackle the limit, though some participants are seeking simpler alternatives. Multiple interpretations of the limit's behavior are being explored, with no explicit consensus reached.
Some participants mention that the problem is from a sample calculus test and express concern about the timing of learning Taylor series in relation to the test. There are also references to computational tools like Maple and Mathematica, indicating a reliance on technology for verification of results.
twoflower
Hi all,
I can't move with this limit:
[tex] \lim_{n \rightarrow \infty} n \left( \left( 1 + \frac{1}{n} \right)^{n} - e \right)[/tex]
Could someone help me please? Or some hint...
But no l'Hospital please.
Thank you
Find out what
[tex] \lim_{n \rightarrow \infty} \left( 1 + \frac{1}{n} \right)^{n}[/tex]
is. It should all be clear from then on.
Well I know it is equal to e, but then
[tex] \lim_{n \rightarrow \infty} n \left( e - e \right) = \lim_{n \rightarrow \infty} n \left ( 0 \right) = 0.\infty[/tex]
Which is undefined...
Are you opposed to using the series expansions of log(1+x) and e^x? You can re-write the (1+1/n)^n term as e^(n*log(1+1/n)). Use the Taylor series for log(1+x), at least 2 terms +remainder. Then you can factor out an e and use the series for e^x, (2 terms+remainder here as well), and that will do it.
If you are opposed to using series but have learned them, it's probably possible to modify the above into a squeeze limit type of proof. If you haven't learned Taylor series yet, I'll have to think of a more elementary method, though it will probably be a thinly disguised version of the above.
Thank you shmoe, maybe this limit is really supposed to be solved using Taylor series, because it is from sample calculus test we're going to take, but as I see in sylabus, we'll learn Taylor series before the test. It confused me, because the sequences are already behind us and I thought I should already be able to solve any limit of sequence...
you cannot sub in the value for e in between the limit like that
i wonder if this will work though
split the limit so you have the limits of n(1-1/n)^n and n e subtracted from each other.
now the limit of n (1-1/n)^n is infinity while the limit of n E is also infinity
however the first one converges to e more slowly that E already does
so n E >n(1-1/n)^n and the limit is negative infinity
The limit should be -e/2...
check what you entered into maple/mathematica/matlab... it isn't -e/2, it is -infinity
No, this won't work. You're essentially saying infinity-infinity=-infinity because the first infinity is getting there slower. This is bunk. An indeterminate infinity-infinity limit form can potentially equal anything we like(-e/2 is correct in this case, done by hand with the method I suggested).
twoflower-series is likely what's intended then. I can't see another way that isn't unnecessarily complicated.
twoflower said:
Hi all,
If you can show that
[tex]-\frac{e}{2n} - \epsilon_1(n) \leq \left( 1 + \frac{1}{n} \right)^{n} - e \leq -\frac{e}{2n} + \epsilon_2(n)[/tex]
Where [itex]\epsilon(n)[/itex] is some expression that goes to zero faster than
[itex]\frac{1}{n}[/itex] then you're set, so perhaps you should look at the convergence of [itex]\left( 1 + \frac{1}{n} \right)^{n}[/itex]
I tried it now. Maple gives -e/2
Nate, do you have a simple method in mind for those inequalities?
The obvious approach to me involves some bounds on log(1+x) and e^x that I would prove using series.
Ok, so you say guys that the most natural way to find this limit is to use Taylor series. If it's right, I will skip this one. Or does anyone have simplier approach to show?
  • · Replies 21 ·
