Statistical Probability Distributions
The discussion revolves around statistical probability distributions, specifically focusing on joint probability distributions of discrete and continuous random variables. Participants are analyzing the transformation of variables and the calculation of probability distributions based on given joint distributions.
  • Exploratory, Conceptual clarification, Mathematical reasoning, Problem interpretation
  • The original poster attempts to find the probability distributions for products and ratios of random variables, raising questions about the correctness of their integration approach for discrete variables.
  • Some participants suggest using summation instead of integration for discrete cases and propose constructing probability tables for clarity.
  • There is a discussion on the implications of the results, particularly regarding the sum of probabilities and the interpretation of an infinite result in one of the questions.
Participants are actively engaging with each other's solutions, providing corrections and alternative methods. Some have pointed out errors in the original calculations and are encouraging a reevaluation of the approaches taken. There is a constructive dialogue about the validity of the results and the methods used to obtain them.
Participants are working under the constraints of homework guidelines, which may limit the extent of assistance provided. The original poster expresses uncertainty about their answers and seeks confirmation, indicating a desire for clarification rather than direct solutions.
Fenix
I have two questions, I've completed. I am partially sure that the answers I've obtained are correct, and all I really want is confirmation on whether they are correct or not. If not, what am I doing wrong?
Question 1:
If the joint probability distribution of X1 and X2 is given by:
F(X1,X2) = (X1X2)/36
Where X1 = 1,2,3, and X2 = 1,2,3
a) Find the probability distribution of X1X2.
Solution:
Y = X1X2
X2 = Y/X1
dX2/dY = 1/X1
g(X1,Y) = [X1(Y/X1)/36][|1/X1|] = Y/36X1, For X1=1,2,3, and Y>0
Therefore, h(y) = Integral from 1 to 3: (Y/36X1)dX1 = Yln3/36, for Y>0
h(y) = 0, elsewhere.
b) Find the probability distribution of X1/X2
Solution:
Y = X1/X2
X2 = X1/Y
dX2/dY = -X1/Y^2
g(X1,Y) = [[X1(X1/Y)]/36][|-X1/Y^2|] = X1^3/36Y^3, For X1 = 1,2,3, and Y>0
Therefore, h(Y) = Integral from 1 to 3: (X1^3/36Y^3)dX1 = 5/9Y^3, for Y>0
h(y) = 0, elsewhere
Question 2:
Consider two random variables X and Y with the joint probability density:
f(X,Y) = {12XY(1-Y), for 0<X<1, 0<y<1.
0, elsewhere
Find the probability density of Z=XY^2 to determine the joint probability density of Y and Z and then integrating out Y.
Solution:
Z = XY^2
X = Z/Y^2
dX/dZ = 1/Y^2
g(Y,Z) = 12(Z/Y^2)(Y)(|1/Y^2|) = 12Z/Y^3, for 0<Y<1, and 0<Z<1
h(y) = Integral from 0 to 1: (12Z/Y^3)dy = Infinity, does not exist.
References: Functions of Random Variables - Transformation Technique of Several Variables.
Thanks in advance. I appreciate it.
Question 1:
Solution:
Y = X1X2
X2 = Y/X1
dX2/dY = 1/X1
These are discrete variables, why do you integrate?
Make tables for probabilities P(X1=i, X2=j) for i, j = 1, 2, 3. For example, P(X1=2, X2=3)=(2*3)/36 = 1/6. You get the same probability when X1=3 and X2=2: P(X1=3, X2=2)=1/6.
Now find the possible values for X1*X2, and the possible values of both X1 and X2 which yield that product.
X1*X2 can have the value of 6 either with X1=2 and X2=3 or with X1=3 and X2=2.
So P(X1X2=6)=P(2,3)+P(3,2)=2*1/6=1/3.
Try to proceed this way.
ehild
You're right, that was a careless mistake.
I've corrected it now.
Instead of integration for Part a)
It should now read:
a)
h(y) = Sigma from X1=1 to 3: (Y/36X1) = Y/36+Y/72+Y/108 = 11Y/216, Y>0
b)
h(y) = Sigma from X1=1 to 3: (X1^3/36Y^3) = (1^3+2^3+3^3)/36Y^3
= 36/36Y^3 = 1/Y^3, Y>0
So how about now? Any other errors?
Also, what about the second question? Doesn't it strike you as odd that the answer is infinity?...
I am afraid you did it entirely wrong. The sum of h(Y)-s for all possible values of x1*x2 which are 1, 2, 3, 4, 6, 9, must be 1. You can check yourself if your values meet this requirement. They do not.
You got h(Y)=11Y/216. The sum for all possible Y-s is 25*11/216 instead of 1.
Now again.
Y=1 can be only if both X1 and X2 is 1. f(X1,X2)=(X1X2)/36=1/36, so h(1)=1/36.
Y=2 is possible if either X1=1 and X2=2 or X1=2 and X2=1. f(1,2)=f(2,1)=2/36.
h(2)=f(1,2)+f(2,1)= 4/36.
Y=3 is obtained by x1=1 and x2=3 or vice versa. f(1,3)=f(3,1)=3/36, h(3)=6/36.
Yo get in the same way that h(4)= f(2*2) = 4/36;h(6)=f(2.3)+f(3,2)=12/36; h(9)=f(3,3)=9/36.
The sum of all h-s is (1+4+6+12+9)/36 =1.
Continue with question b...
ehild
  • · Replies 18 ·
