Vectors Property: Necessary & Sufficient Conditions
  • Context: Graduate
  • Thread starter Thread starter tc
    Property Vectors
The discussion focuses on the necessary and sufficient conditions for N vectors, V_1 to V_N, in an N-dimensional space to ensure that the sum of their projections onto any 2-dimensional plane, represented as complex numbers x_i = a_i + j*b_i, equals zero. The key conclusion is that these vectors must be linearly dependent, meaning at least one vector can be expressed as a linear combination of the others. The proof demonstrates that linear dependence guarantees the required condition, as it leads to the equations necessary for the sum of all {x_i}^2 to equal zero.
  • Understanding of linear dependence in vector spaces
  • Familiarity with complex numbers and their representation
  • Knowledge of projections in multi-dimensional spaces
  • Basic grasp of Cartesian coordinates
  • Study the implications of linear dependence in higher-dimensional vector spaces
  • Explore the properties of projections in different dimensional contexts
  • Learn about complex number operations and their geometric interpretations
  • Investigate the relationship between linear combinations and vector spaces
Mathematicians, physicists, and computer scientists interested in vector analysis, linear algebra, and applications involving projections in multi-dimensional spaces.
tc
Consider N vectors, V_1 ... V_N, (not all zero) in an N-dimensional space. Project these vectors to a 2-dimensional plane, P. Let us denote the results for the i'th vector as (a_i,b_i) in Cartesian coordinates defined on the plane. We will be interested in considering these coordinates as a complex number: x_i = a_i + j*b_i.
Now, these N vectors hold the following property: regardless of the chosen P, the sum of all {x_i}^2 is always equal to 0.
The question: give an explicit description of the property that the N vectors most hold. Prove that this property is both sufficient and necessary.
You should at least say wrt to what basis you're writing the x_i
The property that the N vectors must hold is that they are linearly dependent. This means that at least one of the vectors can be written as a linear combination of the remaining vectors. In other words, there exists a set of coefficients such that when each vector is multiplied by its corresponding coefficient and added together, the result is the zero vector (a vector with all components equal to 0).
To prove that this property is both sufficient and necessary, we will first show that it is sufficient. This means that if the N vectors hold this property, then the sum of all {x_i}^2 will always be equal to 0, regardless of the chosen plane P.
Assume that the N vectors are linearly dependent. This means that there exists a set of coefficients c_1, c_2, ..., c_N (not all zero) such that:
c_1*V_1 + c_2*V_2 + ... + c_N*V_N = 0
Now, let us consider the projection of these vectors onto a 2-dimensional plane P. This projection can be represented by the complex numbers x_i = a_i + jb_i for each vector V_i. Since the vectors are linearly dependent, we can rewrite the above equation as:
c_1*x_1 + c_2*x_2 + ... + c_N*x_N = 0
Expanding this equation, we get:
c_1*(a_1 + jb_1) + c_2*(a_2 + jb_2) + ... + c_N*(a_N + jb_N) = 0
Rearranging terms, we get:
(c_1*a_1 + c_2*a_2 + ... + c_N*a_N) + j(c_1*b_1 + c_2*b_2 + ... + c_N*b_N) = 0
Since the real and imaginary parts of a complex number must both be equal to 0 for the number to be equal to 0, we can conclude that:
c_1*a_1 + c_2*a_2 + ... + c_N*a_N = 0
and
c_1*b_1 + c_2*b_2 + ... + c_N*b_N = 0
But these equations are exactly the conditions for the sum of all {x_i}^2 to be equal to 0. Therefore, we
  • · Replies 0 ·
  • · Replies 16 ·
  • · Replies 16 ·
