New Reply
Calculating Drag Force due to air on a Pedestal Fan blade
Share Thread
Nov10-11, 04:55 AM   #1
I am doing a project where in a pedestal fan is alternatively powered using a flywheel. The flywheel is brought to some initial angular velocity by the electric motor. Now, if the power goes off, the fan blades would be coupled to the flywheel and it continues to rotate for the next 10 minutes.
After the power goes off, we have considered that
Energy-flywheel + Energy-fan = ∫ (Torque-drag force * ω -fan) dt
I'm having trouble calculating the torque due to the drag force and how to geometrically simplify the fan blades.
Any solution would be very much helpful.
PhysOrg.com physics news on PhysOrg.com
>> Is there an invisible tug-of-war behind bad hearts and power outages?
>> Penetrating the quantum nature of magnetism
>> Rethinking the universe: Groundbreaking theory proposed in 1997 suggests a 'multiverse'
Nov10-11, 05:52 AM   #2
Mentor
Welcome to PF!
Why don't you just measure the electrical input to the fan?
Nov11-11, 04:05 AM   #3
Yes, but that would give me the power consumed at some constant fan speed( during operation).
When my flywheel is engaged, the rpm keeps on reducing and is a function of time.
If I know how the drag force is related to angular velocity and how much torque is generated, I would then be able to solve.
Nov12-11, 06:52 AM   #4
Any idea about drag force, Russ?
Nov12-11, 07:37 AM   #5
Mentor
Quote by Kaycee92 View Post
Well, once you have the peak, you can use the fan affinity laws to calculate the power at any rpm. Basically, power is a cube function of rpm.
New Reply
Similar discussions for: Calculating Drag Force due to air on a Pedestal Fan blade
Thread Forum Replies
Calculating stesses in wind turbine blade Mechanical Engineering 0
Drag Force / Drag Coefficient Introductory Physics Homework 5
calculating mean radius of a gas turbine rotor (blade and hub) Engineering, Comp Sci, & Technology Homework 1
Calculating speed in water taking drag force into account Advanced Physics Homework 1
Calculating air drag Introductory Physics Homework 1
