Near and far points with contact lenses
A nearsighted individual with near and far points of 11.0 cm and 22.0 cm, respectively, uses contact lenses with a power of -4.00 D. The focal length of the lens is calculated to be -0.25 m. The new near point is determined to be approximately -7.39 cm, while the far point calculation suggests an image distance of -0.25 m, indicating a potential misunderstanding of the far point concept. The discussion highlights the importance of correctly applying lens formulas to determine new vision parameters after lens application.
  • Understanding of lens power and focal length calculations
  • Familiarity with the lens formula: 1/f = 1/do + 1/di
  • Knowledge of nearsightedness and its optical implications
  • Basic principles of optics related to contact lenses
  • Study the effects of different contact lens powers on vision
  • Learn about the relationship between diopters and focal length
  • Research the concept of near and far points in optics
  • Explore advanced lens formulas and their applications in vision correction
Optometry students, physics students studying optics, and individuals interested in understanding vision correction through contact lenses.
grouper
A nearsighted person has near and far points of 11.0 and 22.0 cm , respectively. If she puts on contact lenses with power P = -4.00 D, what are her new near and far points?
P=1/f
1/f=1/do+1/di where f=focal point, do=distance to object, di=distance to image
The focal length of the lens is -0.25 m (and is a diverging lens, meaning the person is nearsighted). To find the new near point, the distance to the image should be at the naked-eye near point (0.11 m), so 1/-0.25=1/do+1/0.11 makes d0=-7.39 cm the new near point.
I was less sure how do approach the new far point, but I assumed that do=∞ (as it should be in a properly working naked eye) so that 1/-0.25=1/∞+1/di, which makes di=-0.25.
One or both of these answers is incorrect (they are graded together so I can't tell which one) but I have a feeling I'm way off on the far point. I think I'm on the right track with the near point but 7.39 cm seems really close, I think that's better than a normal naked eye. Any suggestions would be appreciated! Thanks.
I figured this one out; don't worry about it.
I still can't figure it out!
Where is the near point of an eye for which a contact lens with a power of 2.30 diopters is prescribed? (Assume that near point for an average viewer is 25 cm.)
s' =0.588 m
Correct
Part B
Where is the far point of an eye for which a contact lens with a power of -1.20 diopters is prescribed for distant vision?
s' = m
I tried using the same equation I did for part A where Power = 1/f, so f = -0.8333333
However with 1/do + 1/di = 1/f I do not have a value of di and if I use 0.25 m I end up with new near point = -0.1923. I have no clue how to get the far point. However, I will continue working on it and maybe if someone else is stuck on this same problem this can help.
EDIT
It occurred to me that di = infinity so 1/do = 1/f!
