| New Reply |
Torque (changing reference frames and adding) |
Share Thread | Thread Tools |
| Nov10-11, 11:47 AM | #1 |
Hello there
I have 2 questions: 1. Can one change the coordinate system of torque vectors through a homogeneous transformation matrix with both rotation and displacement? 2. What's the procedure to add two torque vectors about different axes? Thanks in advance, Joćo |
| Nov10-11, 03:25 PM | #2 |
| Nov10-11, 03:35 PM | #3 |
Thank you! That was a quick reply!
So if I add the two torque vectors, the result will be the net torque about what point? |
| Nov11-11, 04:13 AM | #4 |
Torque (changing reference frames and adding)In the special case, when each of the two torques is generated by a force set which sums to zero, you simply add the two torques. The point of application of that net torque is arbitrary. Also a word of caution on your first question regarding transforming a torque vector to a different coordinate system via a matrix: If one is a right-hand-system and one a left-hand-system you have to apply the 3x3-matrix and negate the torque vector. |
| New Reply |
| Tags |
| coordinate systems, torque, transformations |
| Thread Tools | |
Similar Threads for: Torque (changing reference frames and adding)
| C and frames of reference. | Special & General Relativity | 13 | ||
| reference frames | Linear & Abstract Algebra | 0 | ||
| Frames of Reference | Special & General Relativity | 37 | ||
| Reference frames | Advanced Physics Homework | 4 | ||
| Frames of reference & Inertial frames | Classical Physics | 2 | ||
