Unexpected result with bar fixed to spring with periodic loading
  • Thread starter Thread starter ENgez
    Periodic Spring
The discussion centers on the analysis of a bar fixed to a spring and subjected to periodic loading represented by the function f(x,t)=P_0sin(wt). The expected solution, derived from Hooke's Law, is u(x,t) = P_0sin(wt)/k, but the actual result includes an additional term: u(x,t) = P_0sin(wt)/(k-ρ_{1D}Lw^{2}). This term indicates the influence of frequency on the displacement field, suggesting that rotary inertia plays a role in the system's dynamics. The model utilized is based on the longitudinal displacement equation for bars, confirming the presence of this frequency-dependent term.
  • Understanding of Hooke's Law and its application in mechanics.
  • Familiarity with the longitudinal displacement equation for bars.
  • Knowledge of single-degree-of-freedom (SDOF) vibrating systems.
  • Basic principles of wave mechanics and frequency effects on displacement.
  • Study the implications of rotary inertia in mechanical systems.
  • Research the dynamics of single-degree-of-freedom (SDOF) vibrating systems.
  • Explore advanced concepts in wave mechanics related to periodic loading.
  • Examine the effects of frequency on mechanical displacement in rigid bodies.
Mechanical engineers, physicists, and students studying dynamics and vibrations in mechanical systems will benefit from this discussion.
ENgez
Hi, I solved a steady state problem involving a bar fixed to string in the left side and pulled periodically on the right side [itex]f(x,t)=P_0sin(wt)[/itex]. To check the solution i made E (young's modulus) go to infinity, essentially making the bar rigid. the expression i expected to receive is:
u(x,t) = [itex]\frac{P_0sin(wt)}{k}[/itex]
which is hookes law.
but the expression i received was:
u(x,t) = [itex]\frac{P_0sin(wt)}{k-ρ_{1D}Lw^{2}}[/itex]
the density is one dimensional and L is the bar length.
this expression has an extra term that depends on the frequency which subtracts from the spring constant.
i checked the units and my calculations and they seem to add up. i can't visualize the effect of frequency on the displacement field for a rigid bar. Does this term really "exist" or is this some kind of error?
BTW, the model i used for the bar is the longitudinal displacement equation for bars:
[itex](AEu)''+f(x,t)=ρ\stackrel{..}{u}[/itex]
The "extra" term looks like the rotary inertia of the beam, and a term something like that should be there.
Look up the theory of single-degree-of-freedom (SDOF) vibrating systems.
Thank you, I see it know.
  • · Replies 23 ·
  • · Replies 17 ·
