Help Solving V(t) = e^{2t} - 12t^2+100
  • Thread starter Thread starter ziddy83
The problem involves determining the rates at which water is flowing into and out of a tank, described by the volume function V(t) = e^{2t} - 12t^2 + 100, over the interval 0 ≤ t ≤ 3. The specific questions focus on identifying the times when these rates are maximized and the corresponding rates.
  • Exploratory, Mathematical reasoning, Problem interpretation
  • Participants discuss the need to differentiate the volume function to find the rate of change, dV/dt, and explore how to identify maximum and minimum rates by solving for critical points. There is also mention of evaluating the derivative at the endpoints of the interval.
Several participants have offered guidance on differentiating the volume function and the implications of finding critical points. There is an ongoing exploration of how to determine whether the values found correspond to maximum or minimum rates, with some participants expressing confusion about the evaluation process.
Participants are working within the constraints of the problem, specifically the defined interval for t (0 to 3) and the requirement to find when the rates are maximized or minimized. There is an acknowledgment of the need to test endpoints in the absence of critical points within the interval.
ziddy83
I need help with the following problem...
The volume (in gallons) of water in a tank at time t seconds is given by the function
[tex]V(t) = e^{2t} - 12t^2+100[/tex] where [tex]0 \leq t \leq 3[/tex]
a) when is the water flowing out of the tank at the fastest rate? At what rate is it flowing at this time?
b) When is the water flowing into the tank at the fastest rate? At what rate is it flowing at this time.
So to start this, will i take the derivative of the volume function and then plug in a value to find time T? :confused:
Water is flowing in most quickly when the volume functions is increasing most quickly. So you'd need to maximize the rate of change of the volume, i.e. dV/dt. Water is flowing out most quickly when the volume function is decreasing most quickly, so you'd need to minimize the rate of change of the volume.
So first you differentiate V(t), then it's a simple maximization/minimization problem using y(t) = dV/dt. Maximize and minimize y(t).
--J
cool, thanks
Can someone help me with the max/min part? After i take the derivative...do i then plug in the two values i have been given (0 and 3?) I am a little confused on that part, thanks.
The question is asking for "when", which implies time. THus, take the derivatives, and solve for t when the derivative = 0. AFter you have found your values for t, then you will need to test whether the value is a maximum or a minimum.
(if you don't find a max or min. with these values, then the max or min is porbably either one of the endpoints (i.e, when t = 0 or 3)
Keep in mind that the values for t must be between 0 and 3.
so by simply plugging in the two values in the dv/dt function, i should have my max and min rate? Because when i plug in 3 to the V' function i get 2348.6, and thats...the rate of the water, but how do i know that's the max rate?
oh ok, you just edited your post, thanks
YES i think i got it...thanks to everyone who helped.
  • · Replies 41 ·
