Hot air balloon buoyancy homework
The problem involves a hot air balloon with a specific mass and volume, floating at a constant height. The context centers around buoyancy and the relationship between the densities of the hot air inside the balloon and the outside air.
  • Exploratory, Conceptual clarification, Mathematical reasoning, Problem interpretation
  • Participants discuss the relationship between buoyant force and the weight of the balloon, cargo, and the air inside the balloon. Questions arise regarding how to calculate the density of the hot air and the relevance of the balloon's height.
The discussion has seen various attempts to relate the buoyant force to the weight of the balloon and its contents. Some participants have provided insights into equating forces and calculating densities, while others are exploring the implications of the balloon's height and its constant state of motion.
There is an ongoing examination of the assumptions regarding the density of the air and the implications of the balloon's height being constant. Participants are working within the constraints of the problem without reaching a definitive conclusion.
mikep
A hot air balloon plus cargo has a mass of 291 kg and a volume of 809 m3. The balloon is floating at a constant height of 6.25 m above the ground. The density of the outside air may be assumed to be 1.29 kg/m3. What is the density of the hot air in the balloon?
can someone help me with this problem? i know that i need to use the buoyant force but I'm not sure how to relate the height with the density
I think the height is mentioned only to indicate the balloon is not tethered to the ground and the fact that the height is a constant means the balloon is not accelerating.
oh ok. so how would you find the density? i tried 291/809 = 0.36kg/m^3 but that wasn't correct
Equate the buoyant force to the weight of the balloon, cargo and the air (whose density you do not know) contained in that volume. The buoyant force is the weight of the displaced air and whose density you do know.
so Fb = 1atm + (d)(9.8N/kg)(809m^3) = (1.29kg/m^3)(9.8N/kg)(809m^3) is that right?
[tex]F_b = 1.29 kg/m^3 \times 9.8 m/s^2 \times 809 m^3[/tex]
and the weight of the hot air is
[tex]W_{hot} = \rho_{hot} \times 9.8 m/s^2 \times 809 m^3[/tex]
so the [tex]F_b = W_{hot} + W_{balloon}[/tex] ?
[tex]W_{balloon} = (291kg)(9.8N/kg)[/tex]
[tex]\rho_{hot} = 0.93kg/m^3[/tex]
Way to go, Mike!
9K
