What Is the Oxygen Concentration at the Interior End of a Trachea?
  • Thread starter Thread starter haleyy89
    Diffusion Law
The discussion focuses on calculating the oxygen concentration at the interior end of a trachea, given its length of 1.17 mm, a cross-sectional area of 1.01 x 10-9 m2, an external oxygen concentration of 0.659 kg/m3, a diffusion constant of 1.99 x 10-5 m2/s, and a diffusion mass rate of 1.50 x 10-12 kg/s. The correct formula to determine the change in concentration (deltaC) is deltaC = mL / DA. The final calculated oxygen concentration at the interior end of the trachea is 0.0873 kg/m3, correcting the initial miscalculation of 8.73E8 kg/s.
  • Understanding of diffusion principles in gases
  • Familiarity with the equation m = (DA(deltaC))t / L
  • Knowledge of units for mass concentration (kg/m3)
  • Basic algebra for rearranging equations
  • Study the implications of diffusion constants in biological systems
  • Learn about the effects of tracheal dimensions on gas exchange efficiency
  • Explore advanced diffusion equations and their applications in physiology
  • Investigate the role of environmental factors on oxygen concentration in insect tracheae
Biologists, physiologists, and researchers studying respiratory systems in insects, as well as students learning about gas diffusion principles in biological contexts.
haleyy89
Suppose that a tracheae is 1.17 mm long with a cross-sectional area of 1.01 x 10-9m2. The concentration of oxygen in the air outside the insect is 0.659 kg/m3, and the diffusion constant is 1.99 x 10-5 m2/s. If the mass per second of oxygen is diffusing through a trachea is 1.50 x 10-12 kg/s, then find the oxygen concentration at the interior end of the tube.
m= (DA(deltaC))t / L
I re-arranged the equation to solve for the change in concentration, (delta)C.
deltaC = mL / DA. I know the given value for the outside concentration will be moved over to the other side. I think that the concentration given for the outside of the insect would be the same as initial concentration and the concentration I am solving for would be the final concentration but not exactly sure on this. So I added the concentration given to the other side of the equation to isolate the final concentration. I calculated this to be 8.73E8 kg/s, however this is incorrect. Any suggestions?
deltaC = mL / DA.
You lost the 't' when re-arranging.
Using your formula and data, I make delta C to be 0.0873 kg/m3
9K
