Finding the Length of a Helix Using U-Substitution
  • Thread starter Thread starter BraedenP
The discussion revolves around finding the length of a helix, specifically exploring the mathematical representation and integration involved in the process. The original poster attempts to prove that the length can be expressed using a specific formula involving parameters a and b.
  • Mathematical reasoning, Problem interpretation
  • The original poster presents an integral setup for the length of the helix and expresses confusion regarding the integration process, particularly with u-substitution. Some participants question the validity of the u-substitution approach, suggesting alternative simplifications and clarifications.
Participants are actively engaging with the original poster's approach, offering insights into potential simplifications and questioning the assumptions made in the integration process. There is a recognition of over-complication in the original poster's reasoning, with suggestions for a more straightforward method.
The discussion includes a focus on trigonometric identities and the simplification of expressions within the integral, highlighting the need for clarity in the mathematical setup. The original poster's confusion about the integration process indicates a potential gap in understanding the relationship between the variables involved.
BraedenP
I am trying to prove that the length of a helix can be represented by [itex]2\pi=\sqrt{a^2+b^2}[/itex]
I have the following so far:
If the helix can be represented by [itex]h(t)=a\cdot cos(t)+a\cdot sin(t)+b(t)[/itex]
Then the length is:
[tex]\int_{0}^{2\pi}\sqrt{(-a\cdot sin(t))^2+(a\cdot cos(t))^2+b^2}\;\: dt[/tex]
My problem comes when integrating this. If I use the stuff in the root as u and do u-substitution, then du equals 0dt:
[tex]u=a^2sin^(t)+a^2cos^2(t)+b^2[/tex]
[tex]du=(a^2sin(2t)-a^2sin(2t))dt=0dt[/tex]
My logic fails me when figuring out how to continue from there. I need to somehow represent 1dt. How do I do this?
Help would be awesome!
If your du comes out to be zero, then u must be a constant. What constant is it? Use some trig to simplify your u.
You don't need u-substitution for this problem. Here's why:
Before you try taking the integral, inside the square root, you have a2sin2t + a2cos2t. Factor the a2 out of both of them. What happens?
Yep, was definitely over-thinking it. Thanks guys :)
