Buoyant Pressure problem number 7
  • Thread starter Thread starter ChunkymonkeyI
    Buoyant Pressure
The forum discussion centers on a buoyant pressure problem involving a beaker filled with water, initially weighing 22.0g, and a piece of wood with a density of 0.905 kg/dm³ and a volume of 2.10 cm³. The correct approach to determine the scale reading involves calculating the mass of the wood using the formula m = density × volume, resulting in a mass of 1.905g for the wood. Therefore, the total scale reading should be 23.9g, which includes the mass of the beaker and water plus the mass of the floating wood.
  • Understanding of buoyant force and Archimedes' principle
  • Knowledge of density calculations in different units (kg/dm³ and g/cm³)
  • Familiarity with mass and volume relationships
  • Ability to convert between metric units (cm³ to dm³)
  • Study buoyancy and Archimedes' principle in fluid mechanics
  • Learn about unit conversions between metric measurements
  • Explore density calculations in various contexts, including floating objects
  • Practice similar buoyant pressure problems for better understanding
Students studying physics, particularly those focusing on fluid mechanics, as well as educators and tutors assisting with buoyancy-related homework problems.
ChunkymonkeyI
When a beaker partially filled with water is placed on an accurate scale the scale reads 22.0g. If a piece of wood with a density of 0.905 kg/dm^3 and volume of 2.10 cm^3 is floating on the water, what will the scale read
m=Density times volume
m=density times volume
m=1000 kg/m^3 times 2.1 times 10^-8 m^3
m=2.1 times 10^-8 g
and when I add that to 22.0 g i still get 22.0 g but the answer should be 23.9 g and idk what I'm doing wrong. maybe I didn't account for the object floating on water or something like that so can someone please help me
the mass of the wood is just the density of the wood times the volume of the wood.
I think 22g means the mass of the beaker & water (in grammes). So all you need to do is add the mass of the wood to this mass to get the total mass which the scale will read.
Be careful with the dm and cm units.
  • · Replies 16 ·
