Calculating Molar Mass of Organic Substance w/ Carbon, Hydrogen & Bromine
  • Thread starter Thread starter Mathman23
    Organic
The discussion focuses on calculating the molar mass of an organic substance composed of Carbon, Hydrogen, and Bromine, with a total mass of 1.55 grams. The calculations reveal that the empirical formula is C3H6Br2, derived from the mole ratios of the elements. The actual molar mass of the substance is calculated to be 199.073 g/mol using the ideal gas law under specific conditions. The final molecular formula is confirmed as C3H6Br2, validating the approach taken by the user, Fred.
  • Understanding of molar mass calculations
  • Familiarity with empirical and molecular formulas
  • Knowledge of the ideal gas law (PV=nRT)
  • Basic skills in unit conversions and scientific notation
  • Study the ideal gas law and its applications in chemistry
  • Learn about empirical vs. molecular formulas in organic chemistry
  • Explore advanced techniques for precision in chemical calculations
  • Investigate the significance of significant figures in scientific measurements
Chemistry students, educators, and professionals involved in organic chemistry and stoichiometry will benefit from this discussion, particularly those focusing on molar mass calculations and empirical formula derivation.
Mathman23
Hi I got a question regarding the following calculations:
An organic substance consisting of Carbon, Hydrogen and Bromine and has a total mass of 1,55 grams.
The carbon have a mass of 0,277 grams and the Hydrogen 0,046 grams.
The mass of Bromine is 1,55 g - 0,277 g - 0,046 g = 1,23 grams.
Next I calculate the number moles of Carbin, Hydrogen and Brome.
[itex]n_{Carbon} = \frac{\textrm{0,277 g}}{\textrm{12,01 g/mole}} = \textrm{0,0230} \ \textrm{moles}[/itex]
[itex]n_{Hydrogen} = \frac{\textrm{0,046 g}}{\textrm{1,008 g/mole}} = 0,046 \ \textrm{moles}[/itex]
[itex]n_{Bromine} = \frac{\textrm{1,23 g}}{\textrm{79,9 g/mole}} = \textrm{0,0153} \ \textrm{moles}[/itex]
The mole ratio is a follows 0,023:0,046:0,0153 which can be reduced to 3:6:2.
The emperical formula for the substance is then [itex]C_{3} H_{6} <br /> Br_{2}[/itex]
Next I need to find the molecule's formula : [itex](C_{3} H_{6} Br_{2})_n[/itex]
This is done by calculating the n-value(which is the ratio between the moler masse of [itex](C_{3} H_{6} Br_{2})_n[/itex] and of the actual substance).
The actual molar mass is calculated as follows:
3,006 grams of the actual substance is placed in a container with a volume 500 mL. This is inturn heated to temperature of 150 degress celsius which generates a pressure within the container of 1,047 bars.
[itex]n_{\textrm{actual substance}} = \frac{1,047 atm \cdot 0,500 L}{0,08206 \frac{L \cdot atm}{mol \cdot K}(150 + 273)K } = 0,0151 moles[/itex]
The molar masse for actual substance is then [itex]M_{actual} = \frac{m_{actual}}{n_{actual}}= \frac{3,006 \ g}{0,0151 \ moles} = 199,073 g/mol[/itex]
We can now calculate the n in [itex](C_{3} H_{6} Br_{2})_n:[/itex]
[itex]\frac{M_{actual}}{M_{(C_{3} H_{6} Br_{2})_n} = \frac{201,90 \cdot n }{199,08} : n = 1,014[/itex]
The the molecule's formula is then : [itex]C_{3} H_{6} Br_{2}[/itex]
My question: Is this the correct approach to the above calculations ?
Sincerley
Fred
I would use a fraction to represent each partial result (that you should use later in more complex calculations) and then approximate it. Take a look at the following:
[tex]n_{\mbox{Carbon}} = \frac{0.277 \mbox{ g }}{12.01 \mbox{ g/mole }} = \frac{277}{1210} \textrm{ mole } \approx 2.31 \times 10^{-2} \textrm{ moles }[/tex]
Your approximation was 0.0230 moles (instead of 0.0231 moles). There are three mistakes:
1. Usage of comma vs. point (sometimes it's tricky):
- comma: 100,000 (one hundred thousand)
- point: 2.5 (two point five)
- comma & point: 100,000.56 (one hundred thousand and fifty-six)
NOTE: In South America, for example, people use the opposite notation. Points separate thousands, while a comma separate the integer part from the decimal one.
2. Let's go down one more decimal place. We approximately have: 0.02306. Since the last digit is [tex]N = 6 \geq 5[/tex], we must add 1 to our last decimal place. Otherwise, you would not need to add anything.
3. You may have noticed I used scientific notation up there. Try to stick to it.
Apply the same method to the remaining ones. Keep in mind it's better to use fractions when using results in further calculations.
Hi Fred,
Yes, your approach to the calculations is correct. You have correctly determined the empirical formula of the substance based on the given masses of carbon, hydrogen, and bromine, and then used the molar mass of the actual substance to determine the molecular formula. Your calculations are clear and well-organized, and you have also included the necessary units and conversions. Great job!
11K
11K
