Inductive Reasoning: Si to Sn & i→∞
  • Context: Graduate
  • Thread starter Thread starter Gear300
The discussion revolves around the application of inductive reasoning in mathematics, particularly regarding the implications of statements as they approach infinity. Participants explore the validity of extending truths from finite cases to infinite cases, with a focus on sequences and countability in set theory.
  • One participant suggests that if the truth of Si implies the truth of Si+1, then starting from S1, one could infer the truth of Sn for any natural number n, and questions the validity of extending this to the limit as i approaches infinity.
  • Another participant expresses skepticism about the validity of extending statements true for natural numbers to the entire set of natural numbers, using the example of S_i = "There is a natural number greater than i" to illustrate potential pitfalls in reasoning.
  • A different participant discusses the countability of Cartesian products of countable sets, arguing that while finite products remain countable, the situation becomes complex when considering infinite dimensions, leading to questions about the countability of Nn as n approaches infinity.
  • This participant also connects the discussion to the set of real numbers in the interval [0,1), suggesting that mapping decimal expansions to an infinite-dimensional space raises issues regarding countability.
  • Another reply emphasizes the need for precise definitions when discussing limits and infinity, cautioning against relying on intuitive appeals without rigorous mathematical foundations.
Participants express differing views on the application of inductive reasoning to infinite cases, with some questioning the validity of such extensions. There is no consensus on whether the reasoning applied to finite cases can be reliably extended to infinite cases.
Participants highlight the importance of precise definitions in mathematical reasoning, particularly when discussing limits and infinite processes. There are unresolved questions regarding the implications of inductive reasoning in the context of countability and infinite dimensions.
Gear300
Considering that the truth of Si implies the truth of Si+1, i ε natural numbers, then starting from the truth of S1, one can state the truth of Sn, n being any natural number. I was wondering whether we can make any statement as i→∞, such that the limSi as i → ∞ is also true?
I'm tempted to say "No" immediately because one interpretation of what you mean is "if a statement is true for any given natural number then it is true for the entire set of natural numbers". That wouldn't be valid reasoning. For example: S_i = "There is a natural number greater than i" versus "There is a natural number greater than any number in the set of natural numbers".
What you said mentions: " [itex]lim_{n \rightarrow \infty} S_i"[/itex] and you didn't define what this means. If we take "1" as representing "true" and interpret the limit as a the limit of a numerical sequence, then the limit is 1. But that is a different interpretation than in the previous paragraph.
If we were to check the countability of the cartesian product between two countable sets, A = {a1, a2, a3, ...} and P = {p1, p2, p3, ...}, the resultant set should be countable: If were to consider
{(a1,p1), (a1,p2), (a1,p3), ...} = M1
{(a2,p1), (a2,p2), (a2,p3), ...} = M2
{(a3,p1), (a3,p2), (a3,p3), ...} = M3
Taking the union of all the Mi's results in taking the union of a countable number of countable sets, and so the cartesian product A x P is countable. From this reasoning, we could say that for N = set of natural numbers, Nn for some finite n is countable:
Ni x N = Ni+1
N1 x N = N2 ---> since N is countable, so is N2
N2 x N = N3 ---> since N2 is countable, so is N3, and so forth.
However, if we were to continue this for Nn as n→∞ (an infinite dimensional space), the countability is arguable (I initially thought that it would be countable by inductive reasoning):
Consider the set of real numbers [0,1). This set has power c of the real numbers. We can write each number as some decimal expansion 0.a1a2a3...
We can map these numbers into the infinite dimensional case of Nn by making the correspondence 0.a1a2a3... → (a1,a2,a3,...). [0,1) would then be mapped to a proper subset of Nn (since each decimal place is bounded between 0 and 9, and forms ending in 99999... converge to some other form). Therefore Nn can not be countable for the infinite dimensional case.
I had thought that induction implied that you could apply the condition on Si onto limSi as i → ∞, so I am unsure of whether there is a flaw in this proof somewhere.
That phrase has an intuitive appeal, but to reason precisely about it you have to give it a precise definition. What does it mean? After all, we can say that the limit of a numerical sequence is the result of "continuing a process to infinity", but you can't reliably use that definition in proofs. You have to use the epsilon-delta definition.
  • · Replies 22 ·
  • · Replies 64 ·
