How does a water droplet freeze on a surface without going into too much detail?
  • Context: Undergrad
  • Thread starter Thread starter thephysicsman
    Freezing Water
A water droplet freezes on a surface primarily through heat transfer from the droplet via the water-substrate interface, followed by a nucleation process. This nucleation can be facilitated by minute particles or surface roughness acting as nucleation centers. Heat loss mechanisms include conduction, radiation, and vaporization, with icing nuclei enhancing the freezing process, although they are not strictly necessary. The presence of sufficient icing ions, such as H15O7+, can also initiate freezing.
  • Understanding of heat transfer mechanisms (conduction, radiation, vaporization)
  • Knowledge of nucleation processes in phase transitions
  • Familiarity with surface chemistry and roughness effects
  • Basic concepts of water chemistry, including ionic species
  • Research the role of surface roughness in nucleation processes
  • Explore heat transfer mechanisms in freezing phenomena
  • Investigate the impact of ionic species on freezing points
  • Learn about the thermodynamics of phase transitions in water
Researchers in physical chemistry, materials scientists, and anyone studying the freezing processes of liquids on surfaces.
thephysicsman
Is it correct to say that a water droplet on a surface freezes by heat transfer from the droplet through the water-substrate interface, and a subsequent nucleation process whereby minute particles on the surface (or the surface roughness) acts as nucleation centers?
Do you know of a website/article that explains this without going in too much detail?
Sometimes. The heat loss does not have to be conductive. It can also be radiative, loss of enthalpy via vaporization, or any combination of the three. Icing nuclei are good, and tend to speed things up, but they are not necessary. Sometimes all it takes is the presence of sufficient icing ions (H15O7+). Freezing is a complex phenomena, and does not have simple answers.
  • · Replies 46 ·
20K
  • · Replies 19 ·
11K
16K
  • · Replies 152 ·
12K
