Amphoteric Compounds: Ka of H2PO4 & HS Reaction Explained
  • Thread starter Thread starter Seinfeld4
    Compounds
The reaction between H2PO4 and HS is represented by the formula H2PO4 + HS <--> HPO4 + H2S. The dissociation constant (Ka) values indicate that H2PO4, with a Ka of 6.3 * 10^-8, acts as the acid, donating a proton, while HS, with a Ka of 1.3 * 10^-13, acts as the base, accepting a proton. This conclusion is based on the comparative strength of the acids involved, confirming that H2PO4 is the stronger acid in this amphoteric reaction.
  • Understanding of acid-base chemistry and amphoteric compounds
  • Familiarity with dissociation constants (Ka) and their significance
  • Knowledge of chemical reaction formulas and equilibrium
  • Basic grasp of proton transfer mechanisms in acid-base reactions
  • Study the concept of amphoteric compounds in greater detail
  • Learn about the calculation and significance of dissociation constants (Ka)
  • Research proton transfer mechanisms in acid-base reactions
  • Explore examples of other amphoteric compounds and their reactions
Chemistry students, educators, and professionals interested in acid-base reactions and the behavior of amphoteric compounds in chemical processes.
Seinfeld4
The Ka of H2PO4 is 6.3 * 10^-8. The Ka of HS is 1.3 * 10^-13. Write a formula for the reaction of these substances and explain your results. Both are amphoteric.
The formula is:
I figured that the H2PO4 will act more like the acid in this particular situation because it has a higher value of Ka. So, H2PO4 will donate a proton while HS will receive a proton.
Is this the correct train of thought?
Thanks.
Yes. Just don't ignore charges - use [noparse]-[/noparse] to get -.
9K
14K
  • · Replies 0 ·
  • · Replies 32 ·
