Output Impedance Explained: Simple Answers to Confusing Questions
  • Thread starter Thread starter ananthu
    Impedance Output
The discussion clarifies the concept of output impedance in amplifiers, emphasizing that current amplifiers require low output impedance and high input impedance, while voltage amplifiers necessitate the opposite. It highlights the variability of output impedance in transistors, particularly noting that in the saturation region, impedance is low, whereas in the active region, it is significantly high. The input impedance for a transistor in common emitter mode is defined by the equation Zin = β (r'e + RE), where r'e = Ic/Vt with Vt being 25mV at 25°C. The output impedance is generally approximated as very high, particularly in the active region of operation.
  • Understanding of transistor operation, specifically common emitter and common collector configurations.
  • Familiarity with the concepts of input and output impedance in electronic circuits.
  • Knowledge of basic transistor equations, including the relationship between collector current and thermal voltage.
  • Basic graphing skills to interpret output characteristics of transistors.
  • Research the calculation of output impedance for common emitter and common collector transistor configurations.
  • Learn about the impact of emitter resistors on input impedance in amplifiers.
  • Study the output characteristics of transistors to understand the behavior in different operating regions.
  • Explore the relationship between collector resistor values and output impedance in voltage amplifiers.
Electronics students, educators teaching amplifier concepts, and engineers working with transistor circuits will benefit from this discussion on output impedance and its implications in amplifier design.
ananthu
The concept of output impedance is highly confusing to me.
I will be thankful if some body gives simple explanations to the following.
1. I undertand that in the case of current amplifiers, the out put impedance should be low and the input one should be high. In the case of voltage amplifiers the opposite is true. If you take slope in the saturation region of the output characteristics of a transistor, the impedance will be very low and if you take it on the active region it will be enormously high. If you take it at a point close the knee point it will be intermediate. So it goes on varying. Then how can we judge the right value of output imp. and where it should be measured ?
2.This problem comes while we teach the higher secondary students in the practical class when they draw the graph for the same.
3. The textbooks demand that their output imp. should be lower than the input one. (in the case of NPN transistor in CE mode.
4. In this case I feel another contradiction. Because the theory part says that a transistor is operated in active region as only in that regions the collector current is independent of the coll-emit. voltage. But if you take impedance in that region the output imp. will be higher than the input one.
If I get a detailed explanation it will be useful to me.
I think it will be much more beneficial if you spend the time to understand how the output and input impedance behave. I don't think you can just have a universal statement.
For transistor, the input impedance [itex]Z_{in}=\beta \; (r'_e+R_E)\;\hbox { where }\;r'_e=\frac {I_c}{V_t}\;\hbox { and } \;V_t=25mV \;\hbox { at 25 deg C.}[/itex]
I don't have the equation for output impedance, someone can give you this or I'll find that tomorrow if I have time. It is not important to answer your question. You just regard it to be very high.
I take that your "current amplifier" means common collector or emitter follower. You always have an emitter resistor [itex]R_E\;[/itex], so you can calculate the input impedance from the equation above. The output impedance is [itex]r'_e\;[/itex].
I take that your "voltage amplifier" means common emitter stage with a resistor [itex]R_c\;[/itex] from collector to the power supply. You calculate the input impedance using the equation given. Usually the collector resistor [itex]R_c\;[/itex] is much lower than the output impedance of the transistor, so the output impedance is very very close to just simple [itex]R_c\;[/itex].
You can make your generalization from this.
  • · Replies 23 ·
  • · Replies 38 ·
  • · Replies 47 ·
