Calculate the velocity of the players just after the tackle
  • Thread starter Thread starter bongopukerat
    Velocity
The problem involves a perfectly inelastic collision between two players in a football scenario, focusing on the calculation of their combined velocity after the tackle and the change in kinetic energy resulting from the collision.
  • Participants discuss the application of conservation of momentum to determine the final velocity of the players post-collision. There are inquiries about the implications of a perfectly inelastic collision and how to calculate the change in kinetic energy.
Some participants have provided guidance on using the conservation of momentum and kinetic energy equations. Multiple interpretations of the problem setup are being explored, particularly regarding the directionality of the velocities and the calculations involved.
Participants are considering the definitions of positive and negative directions in relation to the players' movements, which may affect the calculations. There is an emphasis on ensuring the correct application of the momentum conservation principle in the context of the problem.
bongopukerat
Need Help Please!
A 90kg fullback moving south with a speed of 5m/s has a perfectly inelastic collision with a 95kg opponent running north at 3m/s.
a. Calculate the velocity of the players just after the tackle
b. calculate the decrease in total kinetic energy as a result of the collision.
Perfectly inelastic means they stick together so they have a common final velocity. Use the principle of conservation of momentum and the kinetic energy equation for the 2nd one. Show me how you think you would do this question bearing in mind what I've said.
Well, if they have a total inelastic collision then after the collision they move together, as one body, with the same velocity, right?
So all you've got to do is use the momentum conservation law to compare the total momentum before the collision and after it and then find the velocity.
About b, after you've calculate the new velocity then [tex]\Delta E_{k} = E_{k\ total\ after\ collision} - E_{k\ total\ before\ collision}[/tex]
if u call north the positive direction then
[tex] m_1v_1 + m_2v_2 = (m_1 + m_2)v' [/tex]
simple conservation of momentum...
[tex] 90(-5) + 95(3) = 185v'[/tex]
now u can get the velocity just after the collision...
and if u use the kinetic energy equation...
[tex] E_{before} = \frac{1}{2}m_1v_1^2 + \frac{1}{2}m_2v_2^2[/tex]
[tex] E_{after} = \frac{1}{2}(m_1+m_2)v'^2[/tex]
  • · Replies 16 ·
  • · Replies 31 ·
