Maximum power transfer vs Max power efficiency
The discussion centers around the differences between maximum power transfer and maximum power efficiency, exploring their implications in electrical circuits and devices. Participants examine the conditions under which maximum power is transferred to a load and the relationship between power and efficiency in various scenarios.
  • One participant notes that maximum power transfer occurs when the load resistance equals the internal resistance of the power supply, leading to specific current and voltage relationships.
  • Another participant highlights that while maximum power can be transferred, it results in a 50% efficiency due to power being dissipated in the internal resistance.
  • A later reply questions the concept of "power efficiency" when no power is dissipated across the load and internal resistance, suggesting that efficiency discussions may be misleading in certain limits.
  • Participants discuss scenarios where devices may require high voltage rather than high power, seeking examples to illustrate this point.
  • One participant emphasizes the practical application of maximum power transfer in audio systems, specifically mentioning the importance of impedance matching between loudspeakers and amplifiers.
Participants express varying views on the definitions and implications of maximum power transfer and efficiency, with no consensus reached on the interpretation of power efficiency in certain contexts.
Some discussions involve assumptions about circuit conditions, such as the behavior of resistances and the implications of impedance matching, which may not be universally applicable.
fisico30
Hello forum,
what is the main difference between max power transfer and max power efficiency?
In the case of max power transfer, the goal is to transfer the most energy to the load per unit time (impedance matching). Power is I*V and is about delivering energy very fast...
High power means receiving lots of energy very fast or little energy at an even faster rate...
10$/day for a month represents higher power than receiving 10 millions over 10 centuries. the total final amount is less but the per unit time amount is larger...
In the case of power efficiency, it seems to be about the load having the highest voltage. I am not clear why would be a form of power efficiency.How do I need to interpret that in terms of energy?
Some devices need a large voltage and don't care about high power...any example?
thanks
fisico30
Are you familiar with the fact that max power is transferred to a load,R, when R is equal to the internal resistance,r, of the power supply?
If you have a battery with emf = E and internal resistance = r connected to a load resistor = R
Then the current in the circuit I = E/(R+r) and the voltage across the load (the terminal pd)
V= IxR. For example if E =10V, r=5Ω and we make R a large value, let's say 95 then I = 10/100 =0.1A. The power dissipated in the load R = I^2 x R = 0.95W.
If we now make R small, say 1Ω then I =10/6 = 1.67 and the power dissipated in R = 2.8W
Now make R = r = 5Ω Now I = 10/10 =1A and the power dissipated = 1x1x5 =5W.
If you put more values into the equation you will find that 5W is the max power that can be transferred. Ironically it also means that max power is being wasted in the internal resistance which means that the efficiency when max power is being transferred is 50% !
The efficiency is given by (power in load)/(power from battery)
power in load = V x I, power from battery = E x I so efficiencey = VxI/ExI = V/E
this means that the efficiency can only be 100% when V = E but this means something ridiculous !
V can only be equal to E when there is NO CURRENT flowing so the efficiency is 100% when it is doing nothing !
In the limit case where r=0 and R-> infinity the battery voltage is all across the load R.
there is no power dissipated at all. It is strange to talk about "power" efficiency, since neither r or R are receiving any power...
Of course, if r<<<<<R but both are still finite, very little power is output from the battery (the less power as R/r gets bigger) but most of that power is dissipated across R and almost no power dissipated across r...
In the impedance matching case, 50% to r and 50% to R. But that could be 50% of 10000 W.
When there is no impedance matching, R receives almost 100 % of the power, but that power is super small...
That's what we get when we are greedy: you want it all but it is not worth much.
I think I get it now...
But not all devices need a lot of power. Some need a high voltage instead. Any example? All devices need energy though...
Thanks!
fisico
The importance of max power transfer is in cases such as loudspeaker connected to an amplifier. To get max power transferred the resistance (impedance) of the loudspeaker should me 'matched' to the output resistance (impedance) of the amplifier.
Not surprisingly this is called 'impedance matching'
  • · Replies 69 ·
18K
  • · Replies 38 ·
  • · Replies 32 ·
  • · Replies 29 ·
