Lie derivative of two left invariant vector fields
The discussion revolves around the Lie derivative of two left-invariant vector fields within the context of Lie groups, as presented in Nakahara's book. Participants explore the implications of the Lie derivative and the nature of left-invariant vector fields, questioning why the Lie bracket of such fields does not vanish identically despite their defining a one-parameter flow.
  • One participant notes the definition of the Lie derivative of a vector field along the flow of another vector field and questions why the Lie bracket of two left-invariant vector fields does not vanish, given that they define a one-parameter flow.
  • Another participant clarifies that the notation $\sigma_{\epsilon}(x)$ does not represent a left action, but rather a diffeomorphism from the 1-parameter group of diffeomorphisms, emphasizing the distinction between flow and left action.
  • A later reply reiterates the clarification about $\sigma_{\epsilon}$, explaining that it sends each point of the manifold to the point reached after a time $\epsilon$ under the flow, rather than under a left action.
Participants express differing views regarding the interpretation of the notation and the implications for the Lie bracket of left-invariant vector fields. The discussion remains unresolved as there is no consensus on the implications of these definitions.
There is an emphasis on the need for clarity regarding the definitions and roles of the diffeomorphism group and left actions, which may affect the understanding of the Lie derivative and the behavior of left-invariant vector fields.
konik13
Hi all,
I was following Nakahara's book and I really got my mind stuck with something. I would appreciate if anybody could help with this.
The Lie derivative of a vector field [itex]Y[/itex] along the flow [itex]\sigma_t[/itex] of another vector field [itex]X[/itex] is defined as
[tex]L_X Y=lim_{\epsilon\to0}\frac{1}{\epsilon}\left[Y|_{x}-(\sigma_{\epsilon})_* Y|_{\sigma_{-\epsilon}(x)}\right][/tex]
wich is equal to the Lie bracket [itex][X,Y][/itex].
Now when he goes on and defines the left invariant vector field [itex]X[/itex] of a Lie group, this is given by demanding the relation
[tex]L_{a*}X|_g=X|_{a\,g}[/tex]
where [itex]L_a[/itex] is the left translation by [itex]a[/itex].
I guess we can assume that this left translation is the result of a flow of some other field.
My question is that since every left-invariant vector field defines a one parameter flow, why the Lie bracket of two left invariant vector fields doesn't vanish identically?
However, we know that the left invariant vector fields define the Lie algebra of the group and this has non-trivial commutation relations.
Thank you very much for your help.
This is an old question, but since I stumbled upon it when the same confusion briefly bedeviled me after reading Nakahara, I decided to reply in case others follow a similar path. The key is that $\sigma_{\epsilon} (x)$ does not denote a left action. Instead, $\sigma_{\epsilon}$ denotes the diffeomorphism $\sigma_{t} $ with fixed $t=\epsilon$ from the 1-parameter group of diffeomorphisms $\sigma_{t}$ (see Nakahara section 5.3.1). The diffeomorphism group $\sigma_{t}$ is the flow resulting from a vector field, but under $\sigma_{\epsilon}$ you send each point $x$ of the manifold (the manifold being a Lie group in the case discussed here) not to its image under a left action, but rather to the point the flow has reached after $\epsilon$ time elapses, if you start the flow from the point $x$.
If I may, 1729 , let me latex-format your answer to make it easier to read (we use double pounds before - and after - to Latex-tag.:
This is an old question, but since I stumbled upon it when the same confusion briefly bedeviled me after reading Nakahara, I decided to reply in case others follow a similar path. The key is that ##\sigma_{\epsilon} (x) ## does not denote a left action. Instead, ##\sigma_{\epsilon} ## denotes the diffeomorphism ## \sigma_{t} ## with fixed ##t=\epsilon ## from the 1-parameter group of diffeomorphisms ##\sigma_{t} ## (see Nakahara section 5.3.1). The diffeomorphism group ##\sigma_{t} ## is the flow resulting from a vector field, but under ##\sigma_{\epsilon} ## you send each point ##x ## of the manifold (the manifold being a Lie group in the case discussed here) not to its image under a left action, but rather to the point the flow has reached after ##\epsilon ## time elapses, if you start the flow from the point ##x ##
Thank you so much! I couldn't for the life of me figure it out!
  • · Replies 30 ·
  • · Replies 20 ·
