New Reply
Rotating Computer Disk Drive
Share Thread Thread Tools
Nov18-11, 09:06 PM   #1
A computer disk drive is turned on starting from rest and has constant angular acceleration.
If it took 0.690s for the drive to make its second complete revolution, how long did it take to make the first complete revolution?
What is the angular acceleration?
2. Relevant equations
w2 = w02+2[itex]\alpha[/itex]∅
∅=w0t+(0.5)[itex]\alpha[/itex]t2
3. The attempt at a solution
I'm trying to first find the angular acceleration, and from there I can find out how long it took to make the first complete revolution.
First revolution:
w0=0 t=? [itex]\alpha[/itex]=[itex]\alpha[/itex] w=w ∅=2∏
Second revolution:
w0=w t=0.690s [itex]\alpha[/itex]=[itex]\alpha[/itex] ∅=2∏
Second revolution:
2∏ = w0(0.690)+(0.5)[itex]\alpha[/itex](0.690)2
[itex]\alpha[/itex]=[itex]\frac{2∏-w0(0.69)}{(0.5)(0.69)^2}[/itex]
First equation:
w2=w02+2[itex]\alpha[/itex](2∏)
([itex]\frac{2∏-w0(0.69)}{(0.5)(0.69)^2}[/itex])([itex]\frac{2∏-w0(0.69)}{(0.5)(0.69)^2}[/itex])=2[itex]\alpha[/itex](2∏)
I rearranged to get:
4∏2=[itex]\alpha[/itex]((4∏(0.69)2)+(π(0.69)2)-((0.5)(0.69)2))
[itex]\alpha[/itex]=5.45
PhysOrg.com
PhysOrg
science news on PhysOrg.com
>> Galaxies fed by funnels of fuel
>> The better to see you with: Scientists build record-setting metamaterial flat lens
>> Google eyes emerging markets networks
Nov18-11, 10:55 PM   #2
Recognitions:
Homework Helper Homework Help
Quote by PirateFan308 View Post
First revolution:
Second revolution:
Second revolution:
I agree up to this point.
First equation:
Your "velocity-squared" equation is all right, and [itex]\omega_{0} = 0 [/itex] . But doesn't that then lead to
[tex]\omega^{2} = 0^{2} + 4 \alpha \pi \Rightarrow \omega^{2} = 4 \pi \cdot \frac{2 \pi - \omega (0.69)}{(0.5)(0.69)^2} , [/tex]
with [itex]\omega[/itex] being the angular speed at the start of the second revolution? (In fact, your expression in parentheses has units of rad/(sec2), so you can't mean to insert it into the first equation for [itex]\omega [/itex] .)
(And I don't see a much tidier way of doing this, in view of the information given and the fact that there are two unknowns.)
BTW, don't forget to answer the first question about how long the first revolution took.
Nov19-11, 12:33 AM   #3
Mentor
I figured out a couple of different ways to solve this. They both lead me to the same quadratic equation for t2/t1, where t1 is the time required for the first revolution, and t2 is the time required for the second revolution (which we know to be 0.69 s).
Method 1:
Angular displacement between t = 0 and t = t1:
[tex] \Delta \theta = \frac{1}{2}\alpha (\Delta t)^2 \Rightarrow 2 \pi = \frac{1}{2}\alpha t_1^2 [/tex]
[tex]\Rightarrow \alpha = \frac{4\pi}{t_1^2} [/tex]
Angular displacement between t = 0 and t = t2:
[tex] 4 \pi = \frac{1}{2}\alpha (t_1+t_2)^2 [/tex]
[tex] 8 \pi = \frac{4\pi}{t_1^2} (t_1+t_2)^2 [/tex]
[tex] 2 = \frac{t_1^2 + 2t_1t_2 + t_2^2}{t_1^2} [/tex]
[tex] 2 = 1 + 2\frac{t_2}{t_1} + \left(\frac{t_2}{t_1}\right)^2 [/tex]
Letting x = t2/t1, this becomes the quadratic equation:
[tex] x^2 + 2x - 1 = 0 [/tex]
which you can solve.
Method 2:
Angular displacement between t = t1 and t = t2:
[tex] 2\pi = \omega_1 t_2 + \frac{1}{2}\alpha t_2^2 [/tex]
But [itex] \omega_1 [/itex] (the speed at the end of the first revolution) is just [itex] \alpha t_1 [/itex]. Also, if you substitute in the expression for alpha, you get:
[tex] 2\pi = 4\pi \frac{t_2}{t_1} + 2\pi \frac{t_2^2}{t_1^2} [/tex]
[tex] 1 = 2x + x^2 [/tex]
Same quadratic as before. Since you know t2 (it's given), once you solve for x, you have solved for t1. Discard the solution to the quadratic in which the ratio is negative.
Nov19-11, 09:18 AM   #4
Wow, thanks guys! That helped a lot!
Nov19-11, 09:19 AM   #5
One question, how did you format your equations so that they looked so much neater and easier to read?
Nov19-11, 12:02 PM   #6
Mentor
http://www.physicsforums.com/showthread.php?t=546968
New Reply
Tags
angular acceleration, physics, rotating
Thread Tools
Similar Threads for: Rotating Computer Disk Drive
Thread Forum Replies
Tangential speed problem with a hard drive disk Introductory Physics Homework 2
Rotating Disk Introductory Physics Homework 2
Rotating Disk Introductory Physics Homework 6
How to communicate with a 3.5 inch disk drive? Engineering, Comp Sci, & Technology Homework 0
Rotating Disk Special & General Relativity 2
