Entropy of liquid water and water vapor
The discussion revolves around calculating the molar entropy of liquid water and water vapor as functions of temperature, as well as determining the entropy and enthalpy of vaporization. Participants are exploring thermodynamic principles and equations related to these calculations.
  • Exploratory, Conceptual clarification, Mathematical reasoning, Assumption checking
  • Participants discuss using the dS equation with specific heat capacities to derive entropy changes. There is mention of integrating to find changes in entropy and the relationship between enthalpy and entropy during phase changes. Some participants express confusion about the reference temperature for entropy values.
Several participants are actively engaging with the problem, attempting to clarify equations and assumptions. There is a mix of approaches being explored, and while some guidance has been offered, no consensus has been reached regarding the reference temperature for entropy calculations.
Participants note the lack of specific temperatures provided in the problem statement and question the reference values used for entropy and enthalpy in the thermodynamic tables.
jjand
1- Use the thermodynamic table to establish an equation giving the molar entropy of liquid water as a function of temperature. Do the same for water vapor.
2- Use these equations to calculate the entropy of vaporization and the enthalpy of vaporization.
3- From the enthalpy of vaporization of water calculate the total heat transfer, Qwater, when 2 moles of water vapor at 100°C and 1 atm is cooled down to 50°C at constant pressure.
dS = Q/T = Cp*dT/T
dG = dH - TdS
Thermodynamic Constants table is attached
I figured I could just put into the dS equation the values for each respective Cp, then integrate and get deltaS = 75.291*ln(T2/298) for example with liquid water, using 298K for T1 as that is what the Cp value is quoted at. The question doesn't give any other temperatures and it doesn't seem to make sense to me to find a specific entropy, but instead a change in entropy, but maybe I'm thinking this through wrong.
Once I get the first question I know the entropy of vaporization would just be the difference of the individual entropies and the enthalpy of vaporization would be just using the dG equation with dG = 0, but I can't get to this one without figuring out the first one.
1. Δs = Δq/T = Δh/T since Δp = 0. Then s = s0 + Δs(T).
2. ΔG = 0 for phase change = ΔH - T*ΔS. So you use the G column to determine your enthalpy of vaporization ΔH. Then all you need is Cp for kquid water & vapor.
3. Should be able to handle this part now.
PS - I myself am confused about the reference temperature the table assumes for s = 0 and h = 0. I calculated very different values of T0.
Where did the s = s0 + Δs(T) equation come from?
s = 69.9 at T = 298.15K. You are to find s(T) at p = 1 atmosphere.
The change in entropy of water from any temperature between freezing and steam will be
Δs = ∫dq/T integrated from 298.15 to T, 273.15 < T < 373.15.
But dq = dh = cp*dT. So the integral becomes
s(T) = s0 + cp*ln(T/298.15) with cp = 75.3 and s0 = 69.9 per the table. s0 is the constant of integration. Note that at T = 298.15, s = 69.9 as the table says.
I still have no idea why they use s = 69.9 as the entropy at T = 298.15.
  • · Replies 19 ·
