Calculating outlet temperature and heat transfer in an adiabatic spray cooler
The discussion focuses on calculating the outlet temperature and heat transfer in an adiabatic spray cooler using a fine mist of water to cool hot air. The input conditions include a water flow rate of 90 g/s at 30°C and hot air at 450°C and 900 torr. Key calculations involve the Antoine equation for water vapor pressure, mass balance, and energy balance, revealing that the outlet temperature cannot be simply derived from the partial pressure of water. An overall enthalpy balance is necessary to accurately determine the final temperature of the gas mixture.
  • Understanding of the Antoine equation for vapor pressure calculations
  • Knowledge of mass and energy balance principles in thermodynamics
  • Familiarity with ideal gas law and its application
  • Basic concepts of relative and absolute humidity
  • Study the application of the Antoine equation in thermodynamic calculations
  • Learn about performing enthalpy balances in thermal systems
  • Research methods for calculating outlet temperatures in cooling systems
  • Explore the implications of superheated vapor in thermodynamic processes
Engineers, thermodynamicists, and researchers involved in cooling system design, particularly those working with adiabatic spray coolers and heat transfer applications.
cdh5382
Question:
In an adibatic Spray cooler, a fine mist of liquid water is used to cool hot air by evaporating all of the water. The liquid flows in at a rate of 90 g/s and 30°C. The input hot air is at 450°C and 900 torr. The dewpoint of the input air is 47°C and the flow rate is 1362 L/s. Assume no change in pressure occurs for the air stream. Ue the antoine eqn for water.
Relevant eqn's:
Antoine eqn: P*= A-B/(T+c)
Absolte humidity: ha = mass of A in gas/ mass of dry gas
Relative humidity: hr = Pa(T)/P*(T)*100%
Mass balance
Energy Balance
Ideal gas
Progress so far:
I calculated the density of the hot air stream using the ideal gas law and kays rule w/ the assumption that the composition of air is .79 N2 and .21 O2 to be .57379 g/L.
This assumes that the air in was dry air. I suspect that this is where I went wrong. From here I calculated mass flow rate using volumetric flow rate time density.
Mass Balance simplifies to In=Out neglecting the accumulation generation and consumption terms.
I found realtive humidity to be .1152 using mass flow of water / mass flow of air
I found the mol fraction of water in the outlet stream to be
.1557= (90g/s water/18.016 g/mol)/(mol water + (487.93 g/s air)/(28.558 g/mol air)=yw
partial pressure of water is yw*P = .1557*900mmHg = 140.155 mmHg
Using antoine eqn and a= 8.10765 b= 1750.286 c=235 the temperature of water at this partial pressure is 58.66°C.
I don't think I can start using the energy balance w/oknowing the outlet temperature of the air H2O mix. Please help
The outlet temperature is not 58.66 C because the water vapor in the outlet stream is superheated. This problem was not solved correctly. An overall enthalpy balance should have been performed on the device. The only unknown would have been the final temperature of the gas mixture.
