Calculating Area of f(x) from 0 to 3 with 6 Rectangles
  • Thread starter Thread starter Miike012
    Area
The discussion revolves around estimating the area under the curve of the function f(x) = 1 + (x - 1)^2 from x = 0 to x = 3 using the method of Riemann sums with 6 rectangles and right endpoints.
  • Exploratory, Mathematical reasoning, Problem interpretation
  • Participants discuss the use of sigma notation to represent the sum of the areas of rectangles and consider alternative methods for calculating the area. There is also a focus on the accuracy of the final area estimate.
Some participants have provided guidance on the approach to take, while others have pointed out discrepancies in the final area calculation. Multiple interpretations of the problem-solving method are being explored, but there is no explicit consensus on the correct final value.
Participants are operating under the constraints of a homework assignment, which may influence their approaches and the level of detail they provide in their calculations.
Miike012
I just read the section so I want to make sure I am doing it correctly..
I am using it to assist in solving an area question...
Question:
Estimate the area under the graph of f(x) = 1 + (x - 1)^2 from x = 0 to x = 3 using 6 rectangles and right end point.
Each rectangle has a base of 0.5 wide
1. Ʃ 1 + (0.5*i - 1)^2 = i^2/4 - i + 2 ; i = 0 and n = 6
2. Breaking them up:
1/4Ʃ i^2 - Ʃ i + Ʃ 2 ; i = 0 and n = 6
3. Calculating the area of f by computing the sum of the areas of each rectangle in
[0 , 3]
.5( 1/4*(6*13*7)/(6) - (6*7)/2 + 6*2) = 6.85
You could just do it by adding up the six rectangles and skip the sigma notation altogether. That would probably be simpler. But I think you got it right. Except for the final 6.85 number. That's a little off.
I know I could have I just wanted to practice lol..
That's fine. But there an exact value for the sum. And it isn't 6.85.
6.875
