Why Does a Negative Spring Constant Give a Nonreal Period in Oscillation?
  • Thread starter Thread starter bmx_Freestyle
    Oscillation Period
The discussion centers on the implications of obtaining a negative spring constant (k) when calculating the period of oscillation using the formula T=2π(m/k)^(1/2). The user graphed their data points, resulting in a negative slope, which indicates an error in their experimental setup or data collection. The negative value for k leads to a nonreal answer for the period T, highlighting the necessity for a positive spring constant in oscillatory motion. The conversation emphasizes the importance of accurate measurements and understanding the physical principles behind the experiment.
  • Understanding of Hooke's Law and spring constants
  • Familiarity with the formula for the period of oscillation T=2π(m/k)^(1/2)
  • Basic knowledge of graphing data points in physics experiments
  • Experience with measuring force in Newtons and displacement in meters
  • Review the principles of Hooke's Law and its application in oscillatory systems
  • Learn about the significance of positive spring constants in mechanical oscillations
  • Investigate common experimental errors in measuring force and displacement
  • Explore the effects of different types of oscillators, such as pendulums and mass-spring systems
Students conducting physics experiments, educators teaching mechanics, and anyone interested in understanding the principles of oscillation and spring dynamics.
bmx_Freestyle
Ok so i am doing a lab...and i graphed my data points and my slope turned out to be negative.
The y-axis is in Newtons and the x-axis is in Meters.
So my teacher said the the slope=k (constant)
period of an oscillation formula: T=2pi(m/k)^1/2
But my k is negative so when i substitute all my numbers, i get a "Nonreal answer"
What did i do wrong?
You said this was a prac, and you were plotting the results.
What instrument were you using to measure the [Force, in] Newtons;
What instrument were you using to measure the metres;
that you eventually plotted?
What experiment were you actually doing? A pendulum? A mass on a spring? A mass in an inertial balance?
  • · Replies 21 ·
