Generating Plasma During Reentry: The Science Behind Ions in Earth's Atmosphere
  • Thread starter Thread starter Swankie
    Plasma Space
Plasma is generated during space vehicle reentry primarily due to the extreme heat created by air drag. As the vehicle descends, diatomic gases like oxygen and nitrogen dissociate at high temperatures, resulting in the formation of ions. While pressure changes contribute to the heating, it is the heat itself that provides the necessary energy for ionization, not pressure alone. The extreme compression around the vehicle's nose and other areas significantly raises gas temperatures, facilitating this process. Understanding these dynamics is crucial for comprehending the behavior of gases in hypersonic flight.
Swankie
How exactly is plasma generated when space vehicles reenter Earth's atmosphere? How do the ions show up? I get how the air drag creates the initial heat, but from there I do not know. Have been searching the net for about 30min and came up with nada.
When you get that hot, diatomic gases like oxygen and nitrogen begin to dissociate and you end up with with a bunch of ions floating around.
Can someone confirm this? I was under the impression that the pressure, not the heat was the initiator
You need energy for a gas to ionize. Pressure itself doesn't provide that sort of energy. However, the extreme compression that exists near the nose (and a few other areas) of hypersonic vehicles causes the gas to heat up and the heat leads to ionization. It is true that it gets that hot as a result of pressure changes, but it is the heat itself that causes ionization.
Awesome, thanks for the clarification!
Due to the constant never ending supply of "cool stuff" happening in Aerospace these days I'm creating this thread to consolidate posts every time something new comes along. Please feel free to add random information if its relevant. So to start things off here is the SpaceX Dragon launch coming up shortly, I'll be following up afterwards to see how it all goes. :smile: https://blogs.nasa.gov/spacex/
Venus does not have a magnetosphere, so the Galactic Cosmic Rays (GCRs) environment shall be much worse than in a LEO environment. Looking to the std radiation models for Venus, the standard radiation-hard space level electronic component with tested immunity LET = 85 MeV-cm2/mg seems not enough, so, for example, a 1cm2 Si die will suffer considerable flux above this level during a long mission (10 years for example). So, the question is, usually we are not paying attention to latch-up...
