Inner product space and orthonormal basis.
The discussion revolves around finding an orthonormal basis for a subspace W and its orthogonal complement Wperp in the context of inner product spaces, specifically using the standard inner product over the complexes.
  • Exploratory, Conceptual clarification, Mathematical reasoning, Assumption checking
  • Participants discuss the application of the Gram-Schmidt process to generate an orthonormal basis for W and express confusion regarding the correct approach to find Wperp. Questions arise about checking linear independence of the spanning vectors and the implications of applying Gram-Schmidt when linear dependence is present.
There is an ongoing exploration of the relationship between W and Wperp, with some participants suggesting that Wperp should be spanned by two vectors if W is spanned by three linearly independent vectors. Guidance is provided on using dot products to find basis vectors for Wperp, although there is no consensus on the methods or interpretations being discussed.
Participants express uncertainty about the algebraic methods needed to find vectors in Wperp and the implications of using complex numbers in their calculations. There are also references to the constraints imposed by the dimensionality of the space, specifically in relation to \mathbb{C}^5.
Locoism
Assume the inner product is the standard inner product over the complexes.
Let W=
Spanhttp://img151.imageshack.us/img151/6804/screenshot20111122at332.png
Find an orthonormal basis for each of W and Wperp..
Obviously I need to use Gram-Schmidt orthogonalization here, to find the orthonormal basis.
So I've applied the process to W, and normalized each vector to get an orthonormal basis. But I'm confused here as to what I would do for Wperp.. Don't I use G-S on W to find Wperp.? Am I finding the basis of W or am I finding Wperp. by applying G-S, and how am I supposed to find the other one?
If my guess is correct, do I find Wperp. by applying G-S to W, and then the orthonormal basis is each of these vectors normalized? Then I would apply G-S to Wperp. and normalized each of those vectors.
Gram schimdt uses a set of linearly independent vectors to generate a set of orthornormal vectors with the same span.
You have 3 vectors that span W. Are they linearly independent? If so use gram-schmidt to generate a set of 3 orthonormal vectors that span W.
Now consider W perp. As W is spanned by 3 linearly independent vectors (check?), Wperp will be spanned by 2 linearly independent vectors. Note every vector in W perp is orthogonal to the all vectors in W. You could use this fact with dot products to find basis vectors for Wperp.
How am I supposed to check they are linearly independent? Besides that, if they aren't, how would it be possible to use gram-schmidt? Also, how come Wperp will only have 2 vectors? I think I'm missing what you mean when you say use the dot product. There are 6 possible combinations if Wperp has 2 vectors, and each one would equal zero. But wouldn't it take ridiculously long to write them all down and work out each one?
you should probably understand how to check for linear independence prior to using gram-schmidt
Actually you can still attempt gram schimdt and it will come out in the wash that they were and you will end up with a zero vector (when?)
how many vectors span [itex]\mathbb{C}^5[/itex]
its not that bad - you could write the vectors as rows in a matrix, say {w_1,w_2,w_3} span W, and u is a vector in W perp
[tex] \begin{pmatrix}<br /> \textbf{w}_1^{T} \\ \textbf{w}_2^{T} \\ \textbf{w}_3^{T} <br /> \end{pmatrix} \textbf{u} = \textbf{0}[/tex]
Hope this helps, but at the end of the day you have to try some work and ideas out
Ok I just didn't understand since I had already applied GS (and not gotten zero)
So Wperp should be the span of the "remaining" vectors? But why could it not be another set of 3 linearly independent vectors?
Should those w's be the conjugates? (since we are using the standard inner product). I'm not too sure what you're getting at. I know the product should be zero, but how am I supposed to do that algebraically? Do I need to multiply that w matrix by an arbitrary vector an+bni where n is 1 to 5, and then solve? How would I end up with two different sets?
wouldn't you then have 6 linearly independent vectors?
yes, it should be conjugates
write u=(a,b,c,d,e), then you have 5 unknowns whilst the matrix gives you 3 constraints, leading to a subspace spanned by 2 vectors - if you try some of these things it should become obvious
Oh yea.
I was going to do that for u, but shouldn't each a, b, c, d, e be in a complex form? In that case I would have 10 unknowns, and that just wouldn't work.
Also, I'm checking and re-checking my work, but I've ended up with
v1 = [1, 1+i, 1, 1-i, 1]
v2 = [2+i, -2+2i, -2+i, 2+2i, 2i]
v3 = (1/15)[-28+36i, 61-27i, -80i, -27-61i, -28-44i]
After apply G-S, which should give me an orthogonal basis, except these vectors are not orthogonal. I've checked it so many times, why are they not orthogonal?
are you normalizing your vectors first? the norm of |v1|>1
  • · Replies 16 ·
  • · Replies 22 ·
