| New Reply |
Force Required to stop a Rotating Disc |
Share Thread | Thread Tools |
| Nov22-11, 07:36 PM | #1 |
Essentially, I am trying to determine the force that must be applied to a rotating disc to that stop that disc from rotating in a certain time period. The disc is rotating at 5800 rpm, the disc has a radius of 5 inches, and a thickness of 0.087 inches. The disk is made of titanium (density of 4507 kg/m^3). The time required to stop the disk is 0.005 seconds. 2. Relevant equations K = 1/2*I*ω^2 ; I = 1/2*m*r^2 ; -------> K = 1/2(1/2*m*r^2)*ω^2 3. The attempt at a solution Knowing ω = (2∏) / T , I was able to calculate ω to be ω= 607.375 rad/sec Volume of the disc = V = ∏r^2h, which leads to V = 1.1197 E-4 m^3 Using the density, I found the mass of the disk to be m = 0.50465 kg. Plugging all of this into equation above for kinetic energy, I found K to be K = 750.7 joules It's been a while since I took a dynamics course. How can I determine the force necessary (I guess I'm kind of assuming a friction-like force such as a break being applied) to stop the disc from spinning in 0.005 seconds? I know I'll need an integral, but I forget the exact formula and steps necessary to finish up this problem. Thanks! 1. The problem statement, all variables and given/known data 2. Relevant equations 3. The attempt at a solution |
| Nov22-11, 08:06 PM | #2 |
Recognitions:
Hi rjm3db, welcome to Physics Forums.
You've done most of the background calculations for the problem. Consider that in order to go from a speed ω to zero in a given time t that there must be an acceleration [itex]\alpha[/itex]. How might you find that? |
| Nov22-11, 08:23 PM | #3 |
Lets see. So, the angular acceleration is equal to α = dω / dt
So, α = (-607.375 rad / sec) / 0.005 sec → α = -121475 rad / sec^2 Alright, so now I've calculated both the angular acceleration. Any other hints to getting me closer to finishing this one up? It's been a while since I took a dynamics course, but does it involve the equation a = (alpha x r) + (omega x omega x r) , and later on the equation ƩF = ma ? |
| Nov22-11, 08:32 PM | #4 |
Recognitions:
All you need now is the angular equivalent to F = MA to find the torque, then convert the torque to a force applied (presumably) to the rim of the disk.
| Nov22-11, 08:45 PM | #5 |
Great, so something along the lines of
torque = I * α torque = r x F → Force = torque / r ? I really appreciate all of your help. Thanks a bunch |
| Nov22-11, 09:06 PM | #6 |
Recognitions:
| New Reply |
| Thread Tools | |
Similar Threads for: Force Required to stop a Rotating Disc
| Finding the force required to stop an object | Introductory Physics Homework | 2 | ||
| What is the force required and amount of work done to stop this motion? | Introductory Physics Homework | 0 | ||
| What average net force is required to stop..... | Introductory Physics Homework | 1 | ||
| Impulse required to stop a rotating body | General Physics | 6 | ||
| Force needed to stop rotating drum | Calculus & Beyond Homework | 0 | ||
