Maximum Percent Recovery
by JameB
Tags: acetanilide, chemistry, maximum, percent, recovery
JameB
JameB is offline
#1
Nov23-11, 06:11 PM
P: 25
Solubility of acetanilide in water is
5.5g/100mL at 100C
0.53g/100mL at 0C
A 0.150g sample of acetanilide containing only traces of impurities was recrystalized using a total of 3mL of hot water.
a) What is the maximum possible percent recovery of pure acetanilide? Show all steps...
b) By how much would the % recovery be reduced if, during vacuum filtration, the crystals were washed with a total of 20mL of ice cold water?
2. Relevant equations
Percent recovery equation and basic mathematical operations...
3. The attempt at a solution
for a) :=
mass that was recrystallized is 0.150g (is this correct assumption?)
maximum acetanilide that could dissolve in water at 100C is 0.165g (100mL = 5.5g then how much is 3mL...)
which implies that max recovery is (0.15/0.165)*100% = 90.9%
Is this right??!
for b) :=
amount that could dissolve in 20mL cold water= 20*0.53/100 = 0.106g
which implies that amount recovered = 0.150-0.106g = 0.044g
which implies that percent recovery is 0.044/0.165*100 = 26.7%
which means that % recovery will be reduced by 64.2%
Am I correct? Thanks :)
Phys.Org News Partner Science news on Phys.org
Internet co-creator Cerf debunks 'myth' that US runs it
Astronomical forensics uncover planetary disks in Hubble archive
Solar-powered two-seat Sunseeker airplane has progress report
chemisttree
chemisttree is offline
#2
Nov23-11, 07:46 PM
Sci Advisor
HW Helper
PF Gold
chemisttree's Avatar
P: 3,725
Quote Quote by JameB View Post
5.5g/100mL at 100C
0.53g/100mL at 0C
for a) :=
Is this right??!
You are using the solubility of this material at 100C which is good to know but when you recrystallize it the temperature is lowered to near freezing (if you are doing it right). So how much would you lose in 3mL of water at 0C?
JameB
JameB is offline
#3
Nov23-11, 08:36 PM
P: 25
Quote Quote by chemisttree View Post
I would lose 0.0159 at 0C from 0.150g right? (or from 0.165g?)
if I lose 0.0159 then my max percent recovery is [(0.150-0.0159)/0.150]*100=89.4%
Yes?
chemisttree
#4
Nov24-11, 09:03 AM
Sci Advisor
HW Helper
PF Gold
P: 3,725
I'm not going to check your math but using the cold water solubility is certainly the way to go.
Register to reply
Related Discussions
Maximum Percent Recovery? Biology, Chemistry & Other Homework 1
finding maximum speed, maximum acceleration, and maximum resisting force for pendulum Advanced Physics Homework 8
Recrystallization Percent Recovery Biology, Chemistry & Other Homework 1
percent hydrolysis/percent ionazation Biology, Chemistry & Other Homework 1
Oil Recovery Earth 0
