| New Reply |
Summing n-number of Terms to Find the Area of a Polygon |
Share Thread | Thread Tools |
| Nov23-11, 08:16 PM | #1 |
Let C be the line segment connecting the points (x1,y1) and (x2,y2). More over let the line integral over C of (x dy - y dx) = x1y2 - x2y1. Suppose the vertices of a polygon, listed in counter-clockwise order, are (x1y1), (x2y2), ... , (xnyn). Show that the area of the polygon is (1/2) * ((x1y2 - x2y1) + (x2y3 - x3y2) + ... + (xny1 - x1yn)) 2. Relevant equations I don't know a relevant equation, but I suspect there probably is one. 3. The attempt at a solution So, basically, I just want to say something like, let C* be the set of all line segments that connect, with positive orientation, (x1y1), (x2y2), ... , (xnyn). Then using the fact that the line integral over C of (x dy - y dx) = x1y2 - x2y1, and by repeatedly applying this fact, I would have something like: [itex]\sum[/itex] * = 1 n of ([itex]\int[/itex]C* (x dy - y dx)). I think this gives the desired result except for the 1/2, which still eludes me. Also, how do you format these sigmas? It's supposed to read "Sigma from *=1 to n" |
| Nov23-11, 09:28 PM | #2 |
Mentor
[tex]\sum_{i = 1}^n \int_{C^*} (x~dy - y~dx)[/tex]
The LaTeX looks like this (with the spaces in the tex tags removed): [ tex]\sum_{i = 1}^n \int_C^* (x~dy - y~dx)[ /tex] |
| Nov23-11, 09:45 PM | #3 |
Excellent! That's absolutely helpful. Thank you.
I'm thinking about this integral here: Suppose I had integrated line integral over C of (x dy - y dx) to prove that x1y2 - x2y1. Then the parameterization of the curve is r(t) = <x1 + (x2 - x1)*t, y1 + (y2 - y1)*t>. I can calculate a line integral: ∫C x dy - y dx = ∫(0≤t≤1) (x1 + (x2 - x1)*t)*(y2 - y1) - (y1 + (y2 - y1)*t)*(x2 - x1) dt. Calculating gives, (x1 + (1/2)(x2 - x1))*(y2 - y1) - (y1 + (1/2)(y2 - y1))*(x2 - x1). This introduces at least some kind of (1/2) into my calculation. Not sure if that helps though, since the 1/2 just cancels. |
| Nov23-11, 10:02 PM | #4 |
Recognitions:
The area is the integral of (1/2)(xdy-ydx). I think you left the (1/2) out from the very beginning.
| Nov23-11, 10:26 PM | #5 |
Could you please show the calculations that lead you to that conclusion? Certainly there is no 1/2 preceding the "xdy-ydx" in the book, so if there is a typo, it'd be good to know about.
If you'd like to see the problem, it can be found on google books: http://books.google.com/books?id=Vou...int%22&f=false |
| Nov23-11, 10:35 PM | #6 |
Recognitions:
| Nov23-11, 10:39 PM | #7 |
Indeed they did! Guess I should probably start reading the book, huh?
| Nov23-11, 10:46 PM | #8 |
Recognitions:
BTW the easiest proof I know is that the cross product of the three dimensional vectors (x,y,0) and (x+dx,y+dy,0) gives you the area of the parallelogram generated by (x,y,0) and (x+dx,y+dy,0) and the origin. That's xdy-ydx. The area of the triangle from the origin is (1/2) of that. That's dA. I'm sure there is a way to do it without introducing the third dimension, but that's the way I think about it.
| Nov23-11, 10:46 PM | #9 |
Recognitions:
| New Reply |
| Thread Tools | |
Similar Threads for: Summing n-number of Terms to Find the Area of a Polygon
| Infinite summations: area of polygon | Calculus & Beyond Homework | 24 | ||
| Area of complex polygon? | Differential Geometry | 2 | ||
| Polygon of Largest Area. | General Math | 2 | ||
| Complex- area enclosed by a polygon | Calculus & Beyond Homework | 19 | ||
| Finding the Area of a polygon | General Math | 5 | ||
