Does there Exist a Continuous Map ?
  • Context: Graduate
  • Thread starter Thread starter Bacle2
    Continuous Map
The discussion addresses the existence of continuous maps between any two topological spaces (X,T) and (X',T'). It establishes that a continuous map can be defined by finding a function f such that f-1(U) = V for every open set U in T' and some open set V in T. The use of the Axiom of Choice is suggested for infinite cases to assign V for each U, leading to a well-defined map. Additionally, the concept of defining measurable maps between measurable spaces using a similar approach is introduced.
  • Understanding of topological spaces and their properties
  • Familiarity with the Axiom of Choice in set theory
  • Knowledge of continuous functions in topology
  • Basic concepts of measurable spaces and measurable functions
  • Research the Axiom of Choice and its implications in topology
  • Study the properties of continuous maps in topological spaces
  • Explore the relationship between topological spaces and measurable spaces
  • Learn about the construction of measurable functions between measurable spaces
Mathematicians, students of topology, and anyone interested in the foundational concepts of continuous and measurable functions in mathematical analysis.
Bacle2
Hi, All:
I saw this question somewhere else: we are given any two topological spaces (X,T), (X',T'), and we want to see if there is always at least one continuous map between the two. The idea to say yes is this: we only need to find f so that f-1(U)=V , for every U in T', and some V in T. So, it seems , for the infinite case, we could use choice to assign to each U in T' some V in T. Does this give us a well-defined map between (X,T) and (X',T')? It seems like we could then , similarly, define a measurable map between two measurable spaces using the same idea. Does this work?
Thanks.
Just to clarify: I know if X' as above is not empty, then any constant map is continuous; I was just curious to see if the setup above worked.
  • · Replies 20 ·
