Help with Bike Indicator Circuit Project using 6 LEDs
  • Thread starter Thread starter Maxer
    Circuit
The discussion centers on a bike indicator circuit project utilizing 6 LEDs, controlled by a switch to create two distinct flashing sequences. The first sequence lights the LEDs in a cascading manner, while the second sequence, activated by connecting a mode pin to Pin 4 V+ on the LM3914, features a different cascading pattern. Concerns were raised regarding the circuit's reliability, particularly the potential reverse biasing of a PNP transistor connected to an NPN transistor, which could lead to circuit failure. Suggestions included simplifying the input signal circuit by using an adjustable resistor and capacitor to manage the flasher output more effectively.
  • Understanding of LED sequencing and control circuits
  • Familiarity with LM3914 LED driver specifications
  • Knowledge of transistor operation, specifically PNP and NPN types
  • Basic electronics skills, including resistor and capacitor functions
  • Research LM3914 LED driver configuration and applications
  • Learn about transistor biasing and common design pitfalls
  • Explore adjustable resistor and capacitor circuits for signal processing
  • Investigate LED sequencing techniques for visual indicators
Electronics hobbyists, circuit designers, and anyone interested in creating custom LED indicator systems for vehicles.
Maxer
this project is for my bike indicators in the rear with 6 led's
it needs to make 2 sequences as they light up controlled witha switch
here are the sequences
what i am tring to do is have a sequnce LED flash rather then just on and off... here is what i want
Oooooo
OOoooo
OOOooo
OOOOoo
OOOOOo
OOOOOO
then back to
Oooooo
and when mode pin is connected to Pin 4 V+ on LM3914
it should have a different sequence like this
Oooooo
oOoooo
ooOooo
oooOoo
ooooOo
oooooO
and i will add a small switch on the project box i place the circuit in. and the box will be placed in my trunk i can change it periodicaly if i want to.. or have the switch in another place in the front but not sure yet.
Now my circuit is done but i don;t know if it will work..
can you check it out see if you think it might not work?
flasher wire is the wire that's in the rear right now it provides a pluse from factory flasher. so i used transistors as switches...
some one else made this circut for me so i really don't know the values of the resistors and everything
Thanks
max
http://www.electro-tech-online.com/files/lm3914_sequencer_107_105.jpg
Didn't take a lot of time to look it over but the one thing I noticed is that the PNP transistor that has its base hooked to the NPN transistor will most likely have the base emitter juction reverse biased to 12 volts at one time or another. A 3906 will not tolerate a reverse voltage this high on the base emitter junction. I think it's around 6 volts. This is not an uncommon design error. Although some circuits are configured so the base emmiter junction is NEVER reverse biased, those that are often time get overvoltaged.
Just a thought; maybe I'm missing something but...
Why not simplify the input signal circuit with the flasher output feeding through an adjustable resistor to a capacitor, connected to input pin 5? The resistor can be set to give a full scan within the flasher cycle. A second resistor to ground can bleed it to 0 quickly between flashes.
