Lorentz Force: Opposite Currents and Positive Charge Carriers
The discussion revolves around the Lorentz force and its implications for current-carrying wires, particularly focusing on the effects of opposite currents and the nature of charge carriers (positive vs. negative). The scope includes theoretical considerations and conceptual clarifications regarding electromagnetic interactions.
  • One participant describes the Lorentz force effect on parallel wires carrying current in the same direction, noting that they are attracted to each other.
  • A question is posed about the behavior of two wires when one carries current from positive charge carriers in the opposite direction.
  • Another participant asserts that the outcome would be the same regardless of the charge carriers involved.
  • It is noted that two parallel wires carrying current in opposite directions repel each other, which introduces a counterpoint to the previous claims.
  • A further clarification suggests that if one wire has negative charges moving in one direction and the other has positive charges moving in the opposite direction, the repulsion still holds true.
Participants express differing views on the effects of opposite currents in wires, with some asserting that the behavior remains consistent regardless of charge type, while others highlight the repulsive interaction between wires carrying current in opposite directions. The discussion remains unresolved regarding the implications of charge carriers on the Lorentz force.
There are assumptions about the nature of electric current and charge carriers that are not fully explored, particularly regarding the definitions and implications of positive and negative charges in the context of the Lorentz force.
lufc88
'One example of the Lorentz force is that, if two parallel wires are carrying current in the same direction, the wires will be pulled toward each other. The Z-pinch uses this same effect; the entire plasma can be thought of as many current-carrying wires, all carrying current in the same direction, and they are all pulled toward each other by the Lorentz force, thus the plasma contracts. The contraction is counteracted by the increasing gas pressure of the plasma.'
What happens if one wire hypothetically is carrying current carried by positive ions or positive charge carriers but the current traveling in the opposite direction what happens then?
But when two normal parallel wires carrying normal current are carrying the current in opposite directions they repel
If one wire has negative charges traveling in one direction and the other has positive charges traveling in the other direction then what I said is correct. Read the link.
  • · Replies 61 ·
  • · Replies 20 ·
