Understanding Rest, Stillness, Stationarity, Motion, Movement, and Travel
  • Context: High School
  • Thread starter Thread starter JT73
    Terms
The discussion revolves around the definitions and distinctions between the concepts of rest, stillness, stationarity, motion, movement, and travel. Participants explore these terms in a conceptual context, seeking clarity without relying on circular definitions.
  • Some participants propose that "being at rest" and "being stationary" can be defined as having no change in distance or orientation with respect to a reference point.
  • Others argue that to "move" or "to travel" implies a change in distance or orientation relative to a reference point over time.
  • A participant suggests that an object at rest could be considered as being in a state of the slowest possible motion (0 m/s), while another counters that it is in a state of no motion.
  • There is a discussion about teleportation, where some participants claim that teleportation constitutes movement without travel, while others assert that it involves both movement and travel since the object's position changes.
  • Some participants express that the terms being discussed are semantically complex and lack universally accepted definitions, indicating that the conversation is more about semantics than definitive answers.
  • In a separate thread of discussion, participants engage with a hypothetical scenario involving springs, questioning the relationship between motion and energy, and whether energy can be considered stationary while the springs are in motion.
Participants do not reach a consensus on the definitions and relationships between the discussed terms. Multiple competing views remain, particularly regarding the implications of teleportation and the semantics of motion and rest.
The discussion highlights limitations in the definitions provided, as they depend heavily on chosen reference points and the context in which the terms are applied. There is also an acknowledgment of the unresolved nature of some of the mathematical and conceptual aspects discussed.
JT73
This may seem obvious, but please define these for me, in as much details as possible.
What does it mean to:
"be at rest" "be still" "be stationary" "to be in motion" "to move" "to travel"
Please do so without using one of the words in another one's definition (I.e. stationary means to be at rest or to be in motion means to not be at rest)
JT73 said:
This may seem obvious, but please define these for me, in as much details as possible.What does it mean to:
To be "at rest" is synonymous with being "stationary" and it means that your distance with respect to a chosen reference point neither increases, decreases nor changes orientation over time.
To move or to travel means that your distance or orientation with respect to a chosen reference point changes over time.
The key thing to take away from this is that
- none of these terms (moving, rest, stationary) are meaningful without a chosen reference point
- the chosen reference point is arbitrarily chosen out of convenience
So for an object to be at rest or to be stationary could be looked at as being in a state of slowest possible motion (0 m/s)?
Also say teleportation is possible, then if something was teleported from point A to point B, wouldn't it have moved, but not traveled?
No, it would be in a state of no motion.
Since its distance wrt to the reference point has changed, it has indeed moved and travelled.
It's just that it didn't pass through the points in between.
A state of no motion is synonymous with "least possible motion" though? Since least possible motion implies no movement which means no motion.
If I am walking from A to B then I am traveleing from A to B. If I was teleported, then i did not physically travel, but I am now in a new position so I have moved.
*I don't want to come off as me stating I'm right. I just want to clarify thoughts of mine
We're getting into semantics here. The answers aren't really right or wrong - there's no real universal definition of these terms.
Ok, you have indeed helped, thank you.
heres one for you if you had a coiled spring pined to a board that lent on a uncoiled spring, uponen relese the power of that spring onto the other you would create perpetual motion no?
the moving of the springs is motion yet then energy is always stationary in one self
To clarify that, are you trying to say that the springs are in motion, but the springs' energy is "at rest?"
the answer to your question is as follows, if the energy from spring 1 is given to spring 2 has there been distance created with respect to a chosen reference point
To clarify your question the answer is no
I understand what you are saying, I don't understand the point you are trying to make.
that motion itself is motionless, only by distance with respect to a chosen reference point creates oneself
ianpr is confusing the topic more than clarifying. His conundrum can be simply resolved by considering the springs as the system or just a part of a spring as the system.
The same rules still apply. If you pick a reference point, you can determine whether another point is stationary or in motion wrt it.
That was for parallel motion. Now we're talking about perpendicular motion.
danielkbey said:
This may seem obvious, but please figure out these for me, in as much details as possible.
Start a new thread and ask your question.
  • · Replies 20 ·
  • · Replies 37 ·
  • · Replies 24 ·
  • · Replies 64 ·
  • · Replies 34 ·
