Find all solutions of inverse sine (-1/2)
  • Thread starter Thread starter DryRun
    Inverse Sine
The discussion revolves around finding all solutions for the inverse sine of -1/2, with a specified range of angles between 0 and 2π. Participants express confusion regarding the identification of multiple solutions and the application of trigonometric identities.
  • Participants discuss the initial calculation of the inverse sine and the subsequent need to find a second solution. There are attempts to clarify the use of trigonometric identities and the unit circle to identify all possible angles.
Some participants have provided guidance on using the unit circle and trigonometric identities to find additional solutions. There is an ongoing exploration of different methods to derive the second solution, with some participants expressing uncertainty about the application of these concepts.
There is mention of boundaries for the solutions being between 0 and 2π, and participants are grappling with how to properly apply transformations without exceeding these limits. The discussion also highlights the importance of understanding the relationship between sine values and their corresponding angles in different quadrants.
DryRun
Find all solutions of inverse sine (-1/2). Angles lie between 0 and 2∏.
The attempt at a solution
I know it sounds very simple, but i must be having some of the basics wrong, as i can't figure out the second solution.
I used the calculator (in radian mode) to find inverse of sin (-1/2) which gives -∏/6
Since the value of inverse sin (-1/2) must be between 0 and 2∏, i went with the automatic reflex of adding 2∏ to that answer which gives 11∏/6 but then i checked the answer and there is a second solution! And i have no idea how to get that second solution. I need to know a simple, yet consistent method that i can use across all problems of that type, if that's possible.
Keep adding or subtracting 2pi.
This doesn't make any sense. The boundaries are 0 and 2∏. If i keep adding or subtracting 2∏, the value will go overboard.
Example: 11∏/6 + 2∏ = more than 2∏ or -∏/6 - 2∏ = less than zero.
My bad.
Within 0 and 2pi there is one other solution.
You should use the trig identity sin(pi - x)=sin(x)
Your teacher certainly has shown the definition of sine and cosine in the unit circle. Remember: four quadrants, sine and cosine ++ in the first, +- in the second, -- in the third and -+ in the fourth. You have found the solution in the fourth quadrant, still having an other one in the third.
ehild
I've been scribbling and got stuck, as i keep evaluating:
sin (pi - (-1/2)) = sin (-1/2), which are both equivalent, obviously.
I have no idea how to use that formula.
@ehild I know about using CAST on the quadrant. But I'm still stuck as i don't know how to use it to solve for this particular problem, since i only know about adding or subtracting 2pi to get the values but i got only one of the answers using that method. The restriction is that the answers must lie between 0 and 2pi.
You're mixing up the sine with the inverse-sine (aka arcsin).
Try this:
sin( pi - (-pi/6) ) = sin( -pi/6 )
OK, i got the second answer using that formula. 7∏/6
But is that the only way to do it? I would prefer using the quadrant. I plotted the line in the quadrant based on sin (-1/2), so the opposite is -1 and the hypotenuse is 2. The angle is situated in the 4th quadrant. I drew a circle anti-clockwise showing the 2∏ addition that i already used to get the first answer. However, to derive the second answer (7∏/6) from the quadrant still eludes me.
Also, if i had not checked the answers, how would i have known that there are 2 answers? Is there a quick method to know the number of solutions between defined boundaries?
Perhaps you should take a look at the "Unit Circle".
See: http://en.wikipedia.org/wiki/Unit_circle
In this case you are looking for points on the unit circle where the y-coordinate is (-1/2).
There are 2 of them.
OK, other than the first point in the fourth quadrant, i see another point in the second quadrant. But the argument of the second point gives me: pi+ (-pi/6) = 5pi/6 which is not the same answer as that which i obtained using the formula above.
For starters 5pi/6 is in the 2nd quadrant.
But then, you used pi + x, instead of pi - x.
And also you have apparently looked at a point with the same x-coordinate, instead of a point with the same y-coordinate.
That would give you an angle with the same cosine, instead of the same sine.
I have not seen a unit circle in this thread yet...
Unit circle means radius 1. Take a point along the circle and connect it with the centre. The length of that radius is 1 and its projection on the x-axis is x=cosα and the projection on the y-axis is sinα. The radius together with the lines parallel to both axes make a triangle (painted yellow) with hypotenuse equal to 1 and sides of length |sinα| and |cosα|. You see that the angle of this yellow triangle (60° in your case) subtracts from 180° in the second quadrant, adds to 180° in the third one and subtracts from 360° in the fourth quadrant to make the angle in question (in light blue).
To solve a problem when the sin of an angle is given, draw a horizontal line y=sin(α). It intersects the unit circle in two points, giving two angles (the light blue and the pink ones in the figure).
Looking at the figures you can notice that
sin(180°-α)=sin(α)
sin(180°+α)=-sin(α)
and
cos(180°-α)=-cos(α)
cos(180°+α)=-cos(α)
Keep the in mind.
ehild
I finally understand where i made the mistake in this problem. Thank you for your help and patience, ehild and "I Like Serena".
ehild said:
To solve a problem when the sin of an angle is given, draw a horizontal line y=sin(α). It intersects the unit circle in two points, giving two angles.
Can i use this method as a general way to find all the solutions for a given sine, cosine or tan of any given angle? That is, i will first find arcsin, arccos or arctan, and then plot the line and where it intersects the unit circle, i will make a horizontal line that cuts the unit circle at another point, and then i can deduce the other solutions. Correct?
Correct! :smile:
Thanks again. :smile:
  • · Replies 19 ·
