Calculating Density Using Archimedes Principle
The discussion revolves around calculating the density of a wooden block that floats in water, utilizing Archimedes' principle. The problem involves understanding the relationship between the weight of the displaced water and the weight of the floating object.
  • Conceptual clarification, Mathematical reasoning, Assumption checking
  • Participants explore the relationship between the weight of the displaced water and the weight of the floating object. There are attempts to clarify unit conversions and the calculation of forces involved. Questions arise regarding the correctness of initial calculations and the interpretation of forces acting on the object.
The discussion has seen various attempts to clarify the calculations related to buoyancy and density. Some participants have provided corrections regarding unit usage and the application of Archimedes' principle. There is acknowledgment of a correct density value, but the discussion remains open with differing interpretations of the underlying physics.
Participants are working under the constraints of a homework assignment, which may impose specific requirements for the calculations and reasoning presented. There is an urgency expressed by the original poster regarding the need for assistance before an upcoming assessment.
physics kiddy
I have found a question that has got to my nerves :
A block of wood of length 40 cm and area of cross-section 15 cm2 floats in water with 3/8 of it's length above water. What is the density of wood ? (Density of water - 1g/cm3).
My attempt to get the solution :
Length of wood above water = 3/8 * 40 = 15cm
Length of wood below water = (40-15)cm = 25cm
Now, Upthrust = 375cm3*1*10 = 3750 N
Rest, I don't know !
Please help. It's urgent because I am going to face some deadly questions the day after tomorrow. Thank You.
When an object floats and is motionless, its weight exactly equals the upward thrust. The upward thrust is the weight of water displaced.
If you know the weight and volume, you can determine the density.
You have an error with your units. The upward thrust is not 3750 Newtons.
Then what is it ?
You are multiplying cm^3 by grams/cm^3. You do not get Newtons. You get grams. A gram is not a unit of force. Newtons, however, are.
I don't know the purpose of the 10.
kg/m^3 times m^3 times gravitational acceleration(m/sec^2) = Newtons
g=9.8 m/sec^2
alright , first u need to realize that the upthrust force = the wieght of the body...
ie a floating object displaces it's own wieght of the fluid in which it is floating.
so, F1 = upthrust = 0.0375 * 1000 * 10 = 375
and F2 = weight of block = P*V*g =p*0.06*10
so solving this ... my answer comes out to be 0.625g/cm^-3
The upward force is equal to the weight of the water displaced by the body, not the displaced body.
yes sir, u are right , but in this case aas the object is floating thus there has to be no net force (or otherwise it wud produce an acceleration)
so, keeping Newton's 2 nd law in mind, we can come to the conclusion that :
upthrust = weight of the water displaced by the block of wood
and as there is no acceleration hence
upthrust = actuall weight of the block
Please correct me if i am wrong :)
I was correcting your language, not the physics. Yes there is an upward force, but it is not a net force. I never said the upward force was the net force.
.625 gm/cm^3 is the correct result. It's density is 5/8 that of water because 3/8 of its volume remains above the surface of the water.
I had a typo in my previous message. Originally I had typed .675 but meant to type .625 gm/cm^3. It has been corrected.
Oh my god ! I have found the answer. Thanks everybody, thanks.
  • · Replies 18 ·
12K
