[Linear Algebra] Finding T*; complex conjugate linear transformation
The discussion revolves around finding the adjoint of a linear operator T defined on the vector space of real linear polynomials, P_1(R), with a specific inner product. The original poster is tasked with determining T*(p(x)) for an arbitrary polynomial p(x) within this space.
  • Participants discuss the use of an orthonormal basis to find the adjoint and question the implications of T not being self-adjoint. There are attempts to compute inner products and matrix representations, with some participants expressing uncertainty about how to derive T* from the matrices obtained.
The conversation is ongoing, with participants sharing their findings and questioning the steps taken. Some guidance has been offered regarding the use of the Hermitian conjugate in the context of an orthonormal basis, but no consensus has been reached on the final form of T*.
There is a noted difficulty in finding T* due to the non-equality of the matrices representing T and its adjoint, as well as the challenge of constructing a linear mapping from the matrix form. Participants are also considering the implications of the inner product definitions and the properties of linear transformations.
mick25
[Linear Algebra] Finding T* adjoint of a linear operator
Consider [itex]P_1{}(R)[/itex], the vector space of real linear polynomials, with inner product
[itex]< p(x), q(x) > = \int_0^1 \! p(x)q(x) \, \mathrm{d} x[/itex]
Let [itex]T: P_1{}(R) \rightarrow P_1{}(R)[/itex] be defined by [itex]T(p(x)) = p'(x) + p(x)[/itex]. Find [itex]T^*(p(x))[/itex] for an arbitrary
[itex]p(x) = a + bx^2 \in P_1{}(R)[/itex].
[itex]< T(p(x)), q(x) > = < p(x), T^*(q(x)) >[/itex]
Using the standard basis of [itex]P_1{}(R), \alpha = <1, x>[/itex]
[itex]<T(1),1> = 1[/itex]
[itex]<T(1), x> = 1/2[/itex]
[itex]<T(x), 1> = 3/2[/itex]
[itex]<T(x), x> = 5/6[/itex]
[itex] [T]_\alpha^{\alpha} =<br /> \left[ {\begin{array}{cc}<br /> 1 & 3/2 \\<br /> 1/2 & 5/6 \\<br /> \end{array} } \right][/itex]
[itex] [T^*]_\alpha^{\alpha} =<br /> \left[ {\begin{array}{cc}<br /> 1 & 1/2 \\<br /> 3/2 & 5/6 \\<br /> \end{array} } \right][/itex]
Not sure how to find [itex]T^*[/itex] from here...
What you did only works for an orthonormal basis. So perhaps you should first find an orthonormal basis of your space??
I just got the new matrices with the orthonormal basis but I'm still at the same sticking point
The matrices aren't equal so T isn't self-adjoint; that's all I can conclude right now
If you work in an orthonormal basis, then the adjoint is given by the hermition conjugate. So find the hermitian conjugate and express the matrix as a linear transformation. And there you have your adjoint!
[itex]\alpha = <1, \sqrt{3}(2x-1)>[/itex] is an orthonormal basis for [itex]P_1{}(R)[/itex]
By the definition of the inner product space, have
[itex]< T(p(x)), q(x) > = \int_0^1 \! p'(x)q(x) \, \mathrm{d} x + \int_0^1 \! p(x)q(x) \, \mathrm{d} x[/itex]
So I computed
[itex]< T(1), 1 > = 1[/itex]
[itex]< T(1), \sqrt{3}(2x-1) > = 0[/itex]
[itex]< T(\sqrt{3}(2x-1)), 1 > = 4\sqrt3[/itex]
[itex]< T(\sqrt{3}(2x-1)), \sqrt{3}(2x-1) > = 1[/itex]
[itex] [T]_\alpha^{\alpha} =<br /> \left[ {\begin{array}{cc}<br /> 1 & 4\sqrt{3} \\<br /> 0 & 1 \\<br /> \end{array} } \right][/itex]
[itex] [T^*]_\alpha^{\alpha} =<br /> \left[ {\begin{array}{cc}<br /> 1 & 0 \\<br /> 4\sqrt{3} & 1 \\<br /> \end{array} } \right][/itex]
Still not sure how to find [itex]T^*[/itex] from this...
Verifying the matrix...
[itex]< T(p(x)), q(x) > = \int_0^1 \! p'(x)q(x) \, \mathrm{d} x + \int_0^1 \! p(x)q(x) \, \mathrm{d} x = < p(x), T^*(q(x))>[/itex]
[itex]< p(x), T(q(x)) > = \int_0^1 \! p(x)q'(x) \, \mathrm{d} x + \int_0^1 \! p(x)q(x) \, \mathrm{d} x = p(1)q(1) - p(0)q(0) - \int_0^1 \! p'(x)q(x) \, \mathrm{d} x + \int_0^1 \! p(x)q(x) \, \mathrm{d} x[/itex]
So [itex]T[/itex] is not self-adjoint.
Doesn't that matrix for T* actually give you T*?? How do you construct a linear mapping from a matrix?
  • · Replies 24 ·
  • · Replies 16 ·
