Conservation of Angular Momentum of Turntable Problem
The problem involves a turntable with a specified moment of inertia and angular velocity, along with a ball that is thrown and caught by the turntable. The objective is to determine the new angular velocity of the turntable after the ball is caught, which raises questions about the conservation of angular momentum.
  • The original poster attempts to apply conservation of momentum to find the new angular velocity but questions the role of the ball's angular velocity since it is not rotating. Other participants suggest focusing on angular momentum and question whether the ball has angular momentum relative to the axis of the turntable.
Participants are exploring different interpretations of the problem, particularly regarding the conservation of angular momentum versus linear momentum. Some guidance has been offered about considering the ball's linear velocity and its distance from the axis when discussing angular momentum.
There is a noted lack of information regarding the radius of the ball, which raises questions about calculating its moment of inertia. The original poster expresses uncertainty about their calculations and the validity of their approach.
joshualan
A turntable with moment of inertia of 2.0kg*m^2 has a radius of 0.80m and an angular velocity of 1.5 rad/s. A ball is thrown horizontally of 0.4kg at 3.0 m/s and is caught by the turntable by a small and very light cup-shaped mechanism at the turntable's edge. What is the new angular velocity after the ball is caught?
Angular momentum = Moment of Inertia * Angular Velocity
Moment of Inertia of a Disk = (1/2)MR^2
Tangential Velocity = Angular Velocity * Radius
Well, I didn't really think the ball had angular velocity since it wasn't rotating so I found the tangential velocity of the turntable and used the moment of inertia to find the mass of the turntable. I then used the Law of Conservation of Momentum to find the tangential velocity of the turntable with the added mass of the ball. This is what I got:
Mass of Turntable * Tangential Velocity + Mass of Ball * Velocity of Ball = (Mass of Turntable + Mass of Ball) * New Velocity
I then solved for the new velocity which I then used to find the new angular velocity. The answer I got (1.6 rad/s) were not one of the choices in the question so I'm assuming I'm wrong.
How can a non-rotating ball have an angular velocity? I'm sure that this is the key somehow.
The turntable is attached to the axis. The axis exerts force. In such case the linear momentum does not conserve. Work with the angular momentum.
Does the ball have angular momentum with respect to the axis before it is caught at the rim of the turntable? It is small, and does not rotate, but it has a linear velocity and its distance from the axis of rotation is R at that instant.
ehild
ehild
The radius of the ball itself is not given though so how can I calculate its moment of inertia?
It has moment of inertia with respect to the axis. What is the moment of inertia of a point mass m at distance r from the axis?
ehild
  • · Replies 17 ·
18K
10K
